jfc4120
Posts: 449 Joined: Sat Jul 02, 2022 11:16 pm
Post
by jfc4120 » Fri Aug 05, 2022 8:33 pm
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
* Help 1.0.3
I can select a vertex if only two wires(lines) meet. But if another line also intersects there is no way to select it:
Drawing and images attached.
ske_debug.FCStd
(5.74 KiB) Downloaded 22 times
What I need, but if another line is at the vertex as well. s2.png (1.44 KiB) Viewed 878 times
NewJoker
Posts: 3089 Joined: Sun Oct 11, 2020 7:49 pm
Post
by NewJoker » Fri Aug 05, 2022 8:39 pm
I can select it without any issues:
Locale: Polish/Poland (pl_PL)
Willem
Posts: 1854 Joined: Fri Aug 12, 2016 3:27 pm
Post
by Willem » Fri Aug 05, 2022 9:22 pm
Assign the proper snap mode
Schermafdruk van 2022-08-05 23-18-21.png (67.67 KiB) Viewed 795 times
Roy_043
Posts: 8580 Joined: Thu Dec 27, 2018 12:28 pm
Post
by Roy_043 » Fri Aug 05, 2022 9:26 pm
Willem wrote: ↑ Fri Aug 05, 2022 9:22 pm
That's not relevant here.
jfc4120
Post
by jfc4120 » Fri Aug 05, 2022 9:32 pm
@NewJoker how did you select it, I have even zoomed in and it won't highlight for selection.
Snap mode doesn't apply because I'm selecting certain points or vertices to be used in a python program. I will try again.
Roy_043
Post
by Roy_043 » Fri Aug 05, 2022 9:39 pm
I have no problem selecting the top left vertex either. Maybe try to increase the Point Size?
Note that when you select the top left vertex you will select a vertex of the Wire object, and not of the Line object, because the Wire was created first.
jfc4120
Post
by jfc4120 » Sat Aug 06, 2022 12:50 am
I am in draft not sketch, any idea how to increase the point size?
Posts: 54302 Joined: Tue Mar 17, 2015 9:14 am
Post
by chrisb » Sat Aug 06, 2022 6:44 am
jfc4120 wrote: ↑ Sat Aug 06, 2022 12:50 am
View properties->PointSize.
jfc4120
Post
by jfc4120 » Sat Aug 06, 2022 5:21 pm
There is no properties in the view dropdown tab.
NewJoker
Post
by NewJoker » Sat Aug 06, 2022 5:34 pm
jfc4120 wrote: ↑ Sat Aug 06, 2022 5:21 pm
Not there. You have to go to Edit --> Preferences.
