Selecting wire vertex problem
Re: Selecting wire vertex problem
Found point size under appearance. But even after making them huge, I still cannot select the vertex that has another line or wire intersecting.
Try to increasing this parameter.
- Capture.JPG (69.53 KiB) Viewed 697 times
could it be that you are talking about a z-order thing?
fc only has the "top one from current view" selectable.
pics are with wire black points, and the line with brown points, one view is "top", the other "bottom" (points are overemphasized) now, there is a way to get to the "hidden" objects
- make selection view visible
- check the "pick list" box
- select in 3d-view
- select from the list...
- select in 3d-view
I can pick the vertex in 'As Is' drawstyle, but not in 'Wireframe'
indeed, how peculiar - and annoying
What's weird is, as said in wireframe exist the problem. But changing to draw style "as is" or "flat lines" allows picking the vertex.
Have the user pick an edge at a point close to the desired vertex, then
returns the vertex you want.
sel, = Gui.Selection.getSelectionEx()
pp =sel.PickedPoints[0]
edge = sel.SubObjects[0]
dists = [((v.Point - pp).Length, v) for v in edge.Vertexes]
closestVertex = dists[0][1] if dists[0][0] < dists[1][0] else dists[1][1]
Part.show(closestVertex, 'Picked Vertex')
@edwilliams16
That is genius, holy moly how did you learn some of this stuff.
Edit, I get:
And the other end will be selected also, 4 vertices of a face at least is selected.
Edit, I get:
Also I need to integrate into existing code:File "C:/Users/Owner/AppData/Roaming/FreeCAD/Macro/ed_pick.FCMacro", line 15, in <module>
<class 'IndexError'>: list index out of range
selX = FreeCADGui.Selection.getSelectionEx()
PrintMsg = FreeCAD.Console.PrintMessage
PrintMsg("Objects selected:\n")
KOUNT = 0
for sel in selX:
maxname = max((len(name) for name in sel.SubElementNames)) + 4
msg = '{:>%d} ---> (X,Y,Z) = ({:.3f}, {:.3f}, {:.3f})\n' % maxname
PrintMsg(f'{sel.Object.Name} ({sel.Object.Label})\n')
for subName, p in zip(sel.SubElementNames, sel.PickedPoints):
KOUNT = KOUNT + 1
X = p.x * .039370078
Y = p.y * .039370078
Z = p.z * .039370078
######### More code ############
Please see edit in my last reply.
