you have to merge in PartWb and insert everything in Techdraw,
with Partdesign you cannot merge this kind of file, you have clones that will interfere with each other and cause a crash
paragon wrote: ↑Wed Aug 03, 2022 11:04 am
Hi..in my tech draw view the bottom step,riser and 2 spindles are darker than others...can not find where to control this..any help?
You have too much in the Source property. You only need Array, plat1, str2, floor. As it is you are drawing things on top of each other.
