Tech Draw help
paragon
Tech Draw help
Post by paragon »
Hi..in my tech draw view the bottom step,riser and 2 spindles are darker than others...can not find where to control this..any help?
Thanks
OS: Windows 10 Version 1903
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Hash: 68e337670e227889217652ddac593c93b5e8dc94
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.2
Installed mods:
  * A2plus 0.4.56a
  * ArchTextures
  * Assembly4 0.12.3
  * CurvedShapes 1.0.4
  * Curves 0.5.2
  * Design456 0.0.1
  * DynamicData 2.46.0
  * MeshRemodel 1.8919.0
  * Render 2022.2.0
  * Reporting
  * sheetmetal 0.2.53
  * timber
  * workfeature
My Stair2.FCStd
(137.87 KiB) Downloaded 14 times
papyblaise
Re: Tech Draw help
Post by papyblaise »
you have to merge in PartWb and insert everything in Techdraw,
with Partdesign you cannot merge this kind of file, you have clones that will interfere with each other and cause a crash
My Stair2.FCStd
(123.48 KiB) Downloaded 10 times
wandererfan
Re: Tech Draw help
Post by wandererfan »
paragon wrote: Wed Aug 03, 2022 11:04 am Hi..in my tech draw view the bottom step,riser and 2 spindles are darker than others...can not find where to control this..any help?
You have too much in the Source property. You only need Array, plat1, str2, floor. As it is you are drawing things on top of each other.
paragon
Re: Tech Draw help
Post by paragon »
wandererfan wrote: Wed Aug 03, 2022 1:42 pm
Got it!...Thanks so much..
