Angle measure not visible in tech draw
I try to use the tech draw workbench to to render a 2D sketch. I have created a view based on the sketch. This has worked fine. I now need to add a few measures to the drawing. Horizontal and vertical measures work fine. But angle measures show up in the tree but are not visible on the view.
I have attached some screenshots. Has anyone got any ideas on what I need to do to make the measurement visible?
Thanks,
Roger
Thanks,
Roger
- Shalmeneser
Re: Angle measure not visible in tech draw
File ? (version ?)
Sorry,
Forgot the basics.
.FCStd file attached.
Forgot the basics.
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.20.29177 (Git) Snap 161
Branch: tag: 0.20
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.2
Installed mods:
* Help 1.0.3
- dodecagonalbellows.FCStd
- (22.33 KiB) Downloaded 13 times
- Shalmeneser
NO problem for me BUT the angle dimension is far to the right so you need to find it and move it.
- Capture d’écran 2022-08-03 150122.jpg (30.17 KiB) Viewed 838 times
- Shalmeneser
You should not show dimensions on a complete drawing but use a TechDraw_DetailView.
(Your sketch is ... awful : too much lines. You should do a 3D object using Repetition.)
- Capture d’écran 2022-08-03 150716.jpg (27.7 KiB) Viewed 833 times
- papyblaise
you can't have an angle between 2 intersecting lines: which side is the angle?
use the "angle by 3 points" tool
Edit: I spoke: measure the angle between these 2 lines
- dodeca.JPG (48.27 KiB) Viewed 508 times
Thanks for your quick response. I have used freecad in the past but not much. So I am afraid I have another question.
How do I move the measurement? I can select it but I cannot drag it.
Yes my sketch is awful. I plan to simplify it by merging the lines.
Once again thanks for your help.
- Shalmeneser
NO, it's possible.papyblaise wrote: ↑Wed Aug 03, 2022 1:43 pm you can't have an angle between 2 intersecting lines: which side is the angle?
It's the same problem with 2 intersecting lines and Angle tool in Sketcher : one of the angle will be chosen (which one ?).
- Angle with 2 lines.FCStd
- (16.02 KiB) Downloaded 10 times
- wandererfan
Drag the dimension text, not the lines. You probably want to use a bigger font size too (or a magnifying glass!).wearyhacker wrote: ↑Wed Aug 03, 2022 1:52 pm How do I move the measurement? I can select it but I cannot drag it.
- dodecagonalbellows.png (40.18 KiB) Viewed 606 times
- Shalmeneser
(copying the body for the simplified view. But modifying the order of the 1st body would be a better solution, just drawing features before LinearPattern.)
- TechDrawRepetition_SHALM.FCStd
- (103.73 KiB) Downloaded 10 times
- Capture d’écran 2022-08-04 142606.jpg (102.91 KiB) Viewed 504 times
- Capture d’écran 2022-08-04 142927.jpg (65.6 KiB) Viewed 504 times
