Sheetmetal gives "Part Face" object has no attribute "CenterOfGravity"
Roy_043
Re: Sheetmetal gives "Part Face" object has no attribute "CenterOfGravity"
Post by Roy_043 »
PAS_Drafter
Post by PAS_Drafter »
Syres wrote: Tue Aug 02, 2022 6:41 pm It's not a difficult fix (as long as it doesn't cause other regressions).
Hey, I just wanted to say, the problem came back. I went back and doublechecked the SheetMetalCmd.py file to make sure the changes you recommended were still there.
It seems to happen on files that I open that already were "bent" with the previous version of sheetmetal.
I went back and looked at Roy's fix and noticed a few more lines than what you provided. I modified my file with the same changes and reopened the file that gave me the error and it went away. Maybe it is fixed now. I'll keep playing with it. If I keep having problems I'll just go to v.20.
    if hasattr(selFace, "CenterOfGravity") and hasattr(lenEdge.Curve, "projectPoint"):
      pThkDir1 = selFace.CenterOfGravity
      pThkDir2 = lenEdge.Curve.projectPoint(pThkDir1, "NearestPoint")
      thkDir = pThkDir1.sub(pThkDir2).normalize()
    elif hasattr(selFace, "CenterOfGravity") and not hasattr(lenEdge.Curve, "projectPoint"):
       pThkDir2 = lenEdge.Curve.value(lenEdge.Curve.parameter(pThkDir1))
    else:
      thkDir = Cface.normalAt(0,0) * -1
Thanks for your help!
PAS_Drafter
Well, that didn't last long. I did a recompute and the error returned.
Syres
Post by Syres »
PAS_Drafter wrote: Wed Aug 03, 2022 9:06 pm Well, that didn't last long. I did a recompute and the error returned.
Completely deinstall Sheet metal Wb (because you've made manual changes) and reinstall from scratch so you'll get the correct update applied today.
