[solved] how to set Sketch placement?
dprojects
Post by dprojects »
How to set Sketch placement to have exactly the same place as Cylinder. I know how to do it but I don't understand why there placement x,y,z are different. Also the x,y,z depends on plane, so they can change places.
The question is what is the Sketch placement logic? it is live with its own life? how to set it? is there any place I can read about it? what is going on there? I know what is the AttachmentOffset but is there any way to calculate Sketch placement?
For example dowel is at: [250, 9, 580]
and the Sketch is (how to calculate the numbers):
[-250, -9, 0]
the Sketch numbers may not be exactly as dowel starts, but no matter. I am asking about the logic behind the Sketch.
Thanks
Darek
github.com/dprojects
workbench for woodworking is available at: github.com/dprojects/Woodworking
edwilliams16
Re: how to set Sketch placement?
Post by edwilliams16 »
File? It's a lot of work to guess. @dprojects Is the sketch attached? If so, to what?
dprojects
Post by dprojects »
Finally get it to work. I was doing to much with the Sketch.
Thanks
Darek
Re: [solved] how to set Sketch placement?
dprojects wrote: Mon Aug 01, 2022 8:21 pm How to set Sketch placement to have exactly the same place as Cylinder.
Attach the sketch to the cylinder.
dprojects
Post by dprojects »
chrisb wrote: Sun Aug 07, 2022 9:34 am Attach the sketch to the cylinder.
Thanks, but I have already solved this in my own crazy way. Probably I broke all possible Sketch rules but it works very good, I can drill any amount of holes at once and also I can drill thru several pieces of panels and the countersink is in the right place and also the rest of the hole.
However, I delayed the hole feature, because I want to make some kind of machine to move the drill bits in the easy way and also tool (changed the magicDowels) to drill predefined holes in series. The holes feature will be epic. I am not sure it will be legal to share it for free ;-) Maybe if some people see it, they will blow up ;-)
Thanks
Darek
