Issue #7245 - Draw Style have some problems with External file Parts`s Link objects
xsuper9988
Post by xsuper9988 »
1.DrawStyle_WireFrame
If the source object uses the external file Parts Link object
It will cause the DrawStyle_WireFrame mode to fail
2.DrawStyle_Display mode sync update
No Display mode sync update when file switching
PS1:
I found that this problem seems to have happened in ASM4 before but I didn't keep looking for the answer?
But now I found the source of the problem,
Could it come from the "Link Object" function?
Extended reference topic
https://forum.freecadweb.org/viewtopic.php?t=66465
PS2:
The DrawStyle 1st and 2nd issues work fine in the LinkBranch version
3.ShapColor
ShapColor will fail after using RandomColor(solved)
PS: I found that "remove all" in "Override Color" can solve (2022.07.22)
FreeCAD_weekly-builds-29485-2022-07-21-conda-Windows-x86_64-py38
OS: Windows 10 (10.0)
Version: 0.21.29485 (Git)
Hash: a236ca843fdd6674afb6d7ed1454fbd3b547f5ea
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: Chinese/Taiwan (zh_TW)
Installed mods:
  * A2plus 0.4.56a
  * Assembly3 0.11.3
  * Assembly4 0.12.2
  * Curves 0.5.0
  * Design456 0.0.1
  * DynamicData 2.46.0
  * ExplodedAssembly
  * fasteners 0.3.46
  * lattice2 1.0.0
  * Manipulator 1.4.9
  * parts_library
  * pcb
  * sheetmetal 0.2.49
Draw&Color_LinkSource.FCStd
(6.72 KiB) Downloaded 31 times
Draw&Color_Link.FCStd
(3.2 KiB) Downloaded 29 times
Reason: added GH ticket to title
xsuper9988
Re: DrawStyle & ShapColor have some problems with Link objects
Link Branch Ver.
No problems
No problems
3.ShapColor
FreeCAD-asm3-Stable-Win64-Py3-Qt5-20220430
OS: Windows 10 Version 2009
Version: 2022.430.28641 (Git)
Branch: LinkStage3
Hash: a77045488092c24ece25d63c91f362cbd2181d36
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
xsuper9988
Re: Draw Style have some problems with Link objects
3.ShapColor
xsuper9988
Re: Draw Style have some problems with External file Parts`s Link objects
When there is no external file Link object DrawStyle_WireFrame can be executed normally
NoExtFilePartsLinkObj.FCStd
(6.1 KiB) Downloaded 25 times
xsuper9988
This example picture is only a small part of the assembly
In FC standard version if using too many external files Parts Link object
That will affect the "perspective" results of the overall project
I encountered this problem today because I couldn't see through with ASM4 before
Now I try to use more Parts to transform the coordinates
But when too many STEP files are concentrated in the project
It will make the project too fat
Whenever I have to press save it gets very slow
So change the STEP file to "external reference file"
But now I have these problems
Roy_043
Post by Roy_043 »
xsuper9988 wrote: Thu Jul 21, 2022 1:50 pm 1.DrawStyle_WireFrame
Confirmed: an external Link to a Part will not adopt the Std_DrawStyle Wireframe override. Please create an issue on GitHub.
OS: Windows 8.1 (6.3)
Locale: English/United States (en_US) [ OS: Dutch/Netherlands (nl_NL) ]
Installed mods:
xsuper9988
Roy_043 wrote: Sat Jul 23, 2022 7:18 pm Confirmed: an external Link to a Part will not adopt the Std_DrawStyle Wireframe override. Please create an issue on GitHub.
I have created an Issue #7245 on Github
Thank you very much for your help and reply
realthunder
Post by realthunder »
The reason is because the draw style is a per view setting. Since the external linked object lives in another document with a view of different draw style, it is displayed differently. I do have a solution implemented in my branch, but it is not trivial to split it out, and I am quite busy right now. A simpler fix is to just change all depending documents to the same draw style, but I am not sure this is what user wants.
Try Assembly3 with my custom build of FreeCAD at here.
xsuper9988
realthunder wrote: Mon Jul 25, 2022 12:00 pm A simpler fix is to just change all depending documents to the same draw style, but I am not sure this is what user wants.
Does this method give the project(DrawStyle_LinkProject.png) full perspective?
realthunder
xsuper9988 wrote: Mon Jul 25, 2022 12:40 pm Does this method give the project(DrawStyle_LinkProject.png) full perspective?
It is as if you manually set the same draw style (e.g. wireframe) for both document, and you'll get the correct visual.
