Wow, nice community here! Thanks a lot for so much helpful response.
I don't have so much time so it took me a while before I had time but today I found some time to draw again
It seems I understand the freebend feature. Still playing a bit around with it but I'm sure that will work out.
But I have a related question uppon this method of drawing. I need these plates to be relative to eachother. Bolt holes need to line up.
As far as I learned from the information on Youtube and the Wiki page I can use "Create an edge linked to an external geometry (X)" also called "External Geometry". Now I have used this feature succesfully for holes in a plate. But it does not seem to work for two plates relative to eachother. I can't select a point of another plate to align the current one.
I guess I am doing this wrong or using the wrong feature?
Constraints in Sheet Metal?
- Shalmeneser
Re: Constrains in Sheet Metal?
External geometry is for inside a same body (a message informs you below of the ComboView).frnq wrote: ↑Wed Aug 10, 2022 1:18 pm As far as I learned from the information on Youtube and the Wiki page I can use "Create an edge linked to an external geometry (X)" .Now I have used this feature succesfully for holes in a plate. But it does not seem to work for two plates relative to eachother. I can't select a point of another plate to align the current one.
You need a PartDesign_SubShapeBinder to catch geometry for outside the body. Then inside a sketch, you can use external geometry for this binder. It's like an indirect way of external geometry.
- Binder_ShALM.FCStd
- (8.99 KiB) Downloaded 11 times
Here is my file with holes added. I used only Sheetmetal WB and Part WB
- BatteryBracket-New.FCStd
- (68.11 KiB) Downloaded 7 times
Damn, Freecad is no joke to learn. But it has awesome features ones you learned them!Shalmeneser wrote: ↑Wed Aug 10, 2022 1:26 pm External geometry is for inside a same body (a message informs you below of the ComboView).
This is a super powerful feature the ShapeBinder and SubShapeBinder.
Thanks a lot for the help.
I've used this video to learn how to use it:
https://www.youtube.com/watch?v=MCY5IrWrHrU
