Dear Ed,
Is there any reason that the macro would work with a whole sphere, but not half a sphere?
The macro attached is a slightly modified version of the one you wrote: the center of the shell is specified as the origin, and I specify the radial distance and the thickness.
It works perfectly with a full hex-pent sphere, but with a half-sphere, it does not produce the radial webbing, even though it reports no errors. I, of course, have been examining the macro, but I am still at the beginning stages of using and understanding the language.
Are you able to look at this macro yet again?
Thanks! You have been *extremely* helpful!
Request for help from newbie regarding converting polyhedron to wireframe
Re: Request for help from newbie regarding converting polyhedron to wireframe
- Goldberg8inchfacesTOP.step
- upper half, hex-pent sphere
- (460.09 KiB) Downloaded 11 times
- WilliamsHALF.FCMacro
- Slightly modified version of your macro
- (2.52 KiB) Downloaded 10 times
- Goldberg8inchfaces.step
- complete hex-pent sphere
- (903.47 KiB) Downloaded 12 times
The problem is that I assume the input is a solid. Your half version is an open shell. I actually only use the solid to cut away the tiny ears where the struts overlap at the corners. So the following skips that part if it's a shell input.
To get back the clipping functionality, eithert you need to provide a solid STEP input, or I have to create a function to turn your half- shell into one.
#script to make edge structure of HALF a regular polyhedron, presuming the "whole" polyhedron would be centered at the origin
#select the polyhedron in the tree view and run the macro
#Ed williams 7/9/22 modified by Richard Bonomo 8/2/2022 to accomodate half-polyhedrons
#Added code that takes common with an expanded polyhedron. This trims the struts at the corners. 7/11/22
# EW 8/2/22 added output when input is a shell - but without the trim functionality
import Part
from math import degrees
DEBUG = False
if DEBUG:
import ptvsd
print("Waiting for debugger attach")
ptvsd.enable_attach(address=('localhost', 5678))
ptvsd.wait_for_attach()
def radialExtrudeEdge(edge, radialDist, thick, center = App.Vector(0, 0, 0)):
v1, v2 = [v.Point for v in edge.Vertexes]
v1p = (1 + radialDist/(v1 - center).Length)*(v1 - center) + center
v2p = (1 + radialDist/(v2 - center).Length)*(v2 - center) + center
poly = Part.makePolygon([v1, v1p, v2p, v2, v1])
shp = Part.Face(poly)
axis = v2 -v1
midpoint = (v1 + v2)/2
halfangle = degrees((thick/(midpoint - center).Length) * 0.5)
revp = shp.revolve(center, axis, halfangle)
revm = shp.revolve(center, axis, - halfangle)
return revp.fuse(revm)
doc = App.ActiveDocument
sel, = Gui.Selection.getSelection()
edges = sel.Shape.Edges
vertices = sel.Shape.Vertexes
#fuse = True #fusing is slow and sometimes fails
#center = sel.Shape.CenterOfGravity # regular solid so expand around center
center = App.Vector(0.0,0.0,0.0)
radius = (vertices[0].Point - center).Length
#radialDist = radius/10 # input - or specify distance
radialDist = 12.7
# thick = radius/20 # input - or specify distance
thick = 1.14
scale = 1.0 # >1 to try to avoid coplanar issues =1 if you will use uncut shape
fuse = True #can be slow (this is the active fuse status -- uncomment to fuse
shps = []
for edge in edges:
shp = radialExtrudeEdge(edge, radialDist * scale, thick, center)
shps.append(shp)
#fusedshp = shps[0].fuse(shps[1:])
#Part.show(fusedshp, sel.Name + "bumpy_frame")
uncutcmpd = Part.makeCompound(shps)
uncutcmpddoc = Part.show(uncutcmpd, sel.Name + "_uncut_struts")
uncutcmpddoc.ViewObject.Visibility = False
if fuse:
fusion = doc.addObject("Part::MultiFuse",sel.Name + '_uncut_frame')
fusion.Shapes = uncutcmpddoc
fusion.Refine = True
if sel.Shape.ShapeType =='Shell':
App.Console.PrintMessage('Need solid input not shell to cut\n')
else:
lnk = doc.addObject('App::Link',sel.Name)
lnk.setLink(sel)
lnk.Label = sel.Name
lnk.Scale = 1 + radialDist/radius # try to avoid coplanar issues
lnk.Placement.Base = -(radialDist/radius)*center #compensate for scaling moving center
lnk.ViewObject.Visibility = False
shpscut = []
for s in shps:
shpscut.append(lnk.Shape.common(s))
cmpd = Part.makeCompound(shpscut)
cmpddoc = Part.show(cmpd, sel.Name + "_struts")
if fuse:
fusion = doc.addObject("Part::MultiFuse",sel.Name + '_frame')
fusion.Shapes = cmpddoc
doc.recompute()
junk = 0 #provides end breakpoint for debugger
Dear William,
Thank you, again!
When I made the shell, all I had done is take a Goldberg polyhedron STEP file, use the "Defeature" workbench to remove the faces I did not want, and re-exported the result to a new STEP file. Apparently this process makes it no longer a solid?
You are being so generous with your help, I find myself thinking that I should at least send you a Pizza (or something) coupon, if Forum rules allow that!
RB
Thank you, again!
RB
I'm not that familiar with Defeature - but I can understand that if you wanted to get the cutaway shell closed, the code wouldn't know how you wanted it done.bonomo wrote: ↑Wed Aug 03, 2022 12:30 am Dear William,
Thank you, again!
RB
I do this to learn python and FreeCAD and to entertain myself - but you are welcome to donate to FreeCAD, if you think that appropriate.
https://wiki.freecadweb.org/Donate
It finally occurred to me that we don't need to reconstruct a solid to trim the struts as we already have it in hand. Import both Goldberg files and ctrl-select them both, then run the following macro. It was just a few lines of code to refer the solid to the second selection.
#script to make edge structure of a regular polyhedron
#Ed williams 7/9/22
#Ed Williams 8/2/22 for a shell input multi-select both the shell and the corresponding full solid and run
import Part
DEBUG = False
if DEBUG:
import sys
freecadpython = sys.executable.replace('freecad', 'python')
App.Console.PrintMessage('Using ' + freecadpython +'\n')
try:
import debugpy
except ModuleNotFoundError:
App.Console.PrintMessage('Install debugpy by: ' + freecadpython + ' -m pip install --upgrade debugpy\n')
#see https://github.com/microsoft/debugpy/issues/262
debugpy.configure(python=freecadpython)
if not debugpy.is_client_connected():
debugpy.listen(5678)
App.Console.PrintMessage("Waiting for debugger attach\n")
debugpy.wait_for_client()
debugpy.breakpoint()
axis = v2 -v1
sels = Gui.Selection.getSelection()
if len(sels) == 1: #select solid
sel =sels[0]
selsolid = sel
elif len(sels) == 2:
if sels[0].Shape.ShapeType == 'Shell': #select shell and solid
sel = sels[0]
selsolid = sels[1]
else:
sel = sels[1]
selsolid = sels[0]
center = App.Vector(0.0, 0.0, 0.0)
#radialDist = radius/5 # input - or specify distance
radialDist = 12.7
#thick = radius/160 # input - or specify distance
thick = 1.14
scale = 1.1 # >1 to try to avoid coplanar issues
shps = []
for edge in edges:
shps.append(shp)
#Part.show(fusedshp, sel.Name + "_frame")
lnk = doc.addObject('App::Link',selsolid.Name)
lnk.setLink(selsolid)
lnk.Label = selsolid.Name
shpscut = []
for s in shps:
if fuse:
doc.recompute()
