Request for help from newbie regarding converting polyhedron to wireframe
Re: Request for help from newbie regarding converting polyhedron to wireframe
here the file
- 999-edges_as_body.FCStd
- (174.28 KiB) Downloaded 8 times
Marcel a freecad lover
I tried buiding something inspired by your idea.
used downgrade to faces from lattice 2 worbench, then link and scale. then made a lof of outer face and inner face pair. then used thicknesstool in part workbench.. is it something in that direction you want to create?
- icosahedron._faces_loft_thickness.FCStd
- (105.85 KiB) Downloaded 11 times
- icoshedron_faces_loft_thickness.png (10.24 KiB) Viewed 1044 times
- sample Icosahedron honeycomb.png (163.58 KiB) Viewed 1044 times
@bonomo
Here's a script that takes a solid polyhedron and builds a frame edge struts. The struts aren't truncated at the corners. If this is some sort of structure, you'd need to design corner pieces anyway and you can use them subtractively to clean of the extra.
EDIT: Fixed my uploads etc.
#script to make edge structure of a regular polyhedron
#select the polhedron in the tree view and run the macro
#Ed williams 7/9/22
import Part
from math import degrees
DEBUG = False
if DEBUG:
import ptvsd
print("Waiting for debugger attach")
ptvsd.enable_attach(address=('localhost', 5678))
ptvsd.wait_for_attach()
doc = App.ActiveDocument
sel, = Gui.Selection.getSelection()
edges = sel.Shape.Edges
vertices = sel.Shape.Vertexes
def radialExtrudeEdge(edge, radialDist, thick, center = App.Vector(0, 0, 0)):
LS = Part.LineSegment
v1, v2 = [v.Point for v in edge.Vertexes]
v1p = (1 + radialDist/(v1 - center).Length)*(v1 - center) + center
v2p = (1 + radialDist/(v2 - center).Length)*(v2 - center) + center
poly = Part.makePolygon([v1, v1p, v2p, v2, v1])
shp = Part.Face(poly)
axis = v2 -v1
midpoint = (v1 + v2)/2
halfangle = degrees((thick/(midpoint - center).Length) * 0.5)
revp = shp.revolve(center, axis, halfangle)
revm = shp.revolve(center, axis, - halfangle)
return revp.fuse(revm)
fuse = False #fusing is slow and sometimes fails
center = sel.Shape.CenterOfGravity # regular solid so expand around center
radius = (vertices[0].Point - center).Length
radialDist = radius/20 # input - or specify distance
thick = radius/20 # input - or specify distance
shps = []
for edge in edges:
shp = radialExtrudeEdge(edge, radialDist, thick, center)
shps.append(shp)
if fuse:
fusedshp = shps[0].fuse(shps[1:])
Part.show(fusedshp, sel.Name + "_frame")
else:
cmpd = Part.makeCompound(shps)
Part.show(cmpd, sel.Name + "_struts")
- polyhedronstruts.FCStd
- (783 KiB) Downloaded 13 times
it exactly does your OP #1 question (or q in title)...
nothing more nothing less
my attempts are stupid handwork compared to that elegant script...
But anyway i managed to make something....
Used workbenches:
part lattice2(addon) Pyramids-and-Polyhedrons (addon)
When you load the fcstd both addons must be installed otherwise you get errors...
Used workbenches:
- dodekaeder_honeycomb.png (149.81 KiB) Viewed 915 times
- dodecahedron_honeycomb.FCStd
- (182.48 KiB) Downloaded 12 times
thx for the awesome script edwilliams16.edwilliams16 wrote: ↑Sat Jul 09, 2022 8:10 pm @bonomo
Screen Shot 2022-07-09 at 9.56.32 AM.pngScreen Shot 2022-07-09 at 9.57.08 AM.png
I used your script on a Icosahedron created with Pyramids-and-Polyhedrons(addon). great result.
To transform the result of your script into a structure containing only one body the following actions were taken:
1. create Icosahedron-> Icosahedron
2. run macro struts->Icosahedron_struts
3. link the icosahedron and scale it in properties -> Icosahedron001
4. select Icosahedron_struts and fuse with lattice2 fuse_compound -> FuseCompound
5. part worbench boolean cut FuseCompound with Icosahedron001-> Cut
6. cut FuseCompound wit Cut -> Cut001
now you have 1 solid Body that has the overlapping corners removed. Attention lattice2 addon must be installed to open fcstd file
- Icosahedron_struts_1_body.FCStd
- (536.47 KiB) Downloaded 13 times
- Ikosahedron_1_body_clean.png (212.74 KiB) Viewed 886 times
- Ikosahedron_using_script.png (260.81 KiB) Viewed 893 times
Good idea. Also Lattice2's fuse_compound worked in this case where the Part fuse() failed. Maybe I'll rewrite the script to use that, but it would put a dependency on Lattice2, and the additional process is pretty simple.intufreecad wrote: ↑Sun Jul 10, 2022 8:58 pm
Part Boolean|intersection is more straightforward than two cuts.
- truncated_icosahedron_cleaned.FCStd
- (1000.01 KiB) Downloaded 13 times
@bonomo @intufreecad
Seems like some of the difficulties I was having with more complex polyhedra were co-planar issues. This seems to be robust:
#select the polyhedron in the tree view and run the macro
#Ed williams 7/9/22
#Added code that takes common with an expanded polyhedron. This trims the struts at the corners. 7/11/22
import Part
DEBUG = False
if DEBUG:
import ptvsd
axis = v2 -v1
#fuse = True #fusing is slow and sometimes fails
radialDist = radius/10 # input - or specify distance
scale = 1.1 # >1 to try to avoid coplanar issues
fuse = True #can be slow
shps = []
for edge in edges:
shp = radialExtrudeEdge(edge, radialDist * scale, thick, center)
shps.append(shp)
#fusedshp = shps[0].fuse(shps[1:])
#Part.show(fusedshp, sel.Name + "_frame")
lnk = doc.addObject('App::Link',sel.Name)
lnk.setLink(sel)
lnk.Label = sel.Name
lnk.Scale = 1 + radialDist/radius # try to avoid coplanar issues
lnk.Placement.Base = -(radialDist/radius)*center #compensate for scaling moving center
lnk.ViewObject.Visibility = False
shpscut = []
for s in shps:
shpscut.append(lnk.Shape.common(s))
cmpd = Part.makeCompound(shpscut)
cmpddoc = Part.show(cmpd, sel.Name + "_struts")
cmpddoc.ViewObject.Visibility = False
if fuse:
fusion = doc.addObject("Part::MultiFuse",sel.Name + '_frame')
fusion.Shapes = cmpddoc
fusion.Refine = True
doc.recompute()
junk = 0 #provides end breakpoint for debugger
Just an interested observer of this thread who happens to like structures. Call me crazy if you wish but when I saw the models on this page I immediately thought of Buckminster Fuller and his geodesic domes.
https://www.archdaily.com/572135/ad-cla ... ter-fuller
I was wondering if you could model something of this magnitude using the methods described above?
If I have wandered too far off topic please let me know and I will remove my post.
If you keep the struts separate. Fusing them together at that scale would be verrry slow.Laurie Hartley wrote: ↑Tue Jul 12, 2022 4:06 am Just an interested observer of this thread who happens to like structures. Call me crazy if you wish but when I saw the models on this page I immediately thought of Buckminster Fuller and his geodesic domes.
