[Solved] Sketcher CreatePolyline mode cycle shortcut
thyssentishman
Post by thyssentishman »
Hi all,
for some reason when I use the CreatePolyline tool in the Sketcher WB I can only cycle through its different modes using the Shift+M key combination even though the tool hint and corresponding wiki page instruct only using the M key.
Is this normal?
Kind regards,
Johannes
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: English/United States (en_US) [ OS: English/United States (en_US) ]
Installed mods:
  * A2plus 0.4.56a
  * Curves 0.5.0
  * fasteners 0.3.46
  * Render 2022.2.0
EDIT: Corrected typo in title
Last edited by thyssentishman on Wed Jul 06, 2022 11:01 am, edited 3 times in total.
openBrain
Re: Sktecher CreatePolyline mode cycle shortcut
Post by openBrain »
What is your Mouse navigation style please ?
drmacro
Post by drmacro »
M key works as advertised in Debian and Manjaro. Maybe a Windows thing.
thyssentishman
openBrain wrote: Wed Jul 06, 2022 10:13 am What is your Mouse navigation style please ?
I use CAD.
drmacro wrote: Wed Jul 06, 2022 10:14 am M key works as advertised in Debian and Manjaro. Maybe a Windows thing.
Hmm maybe. :?
Kind regards,
Johannes
openBrain
Post by openBrain »
thyssentishman wrote: Wed Jul 06, 2022 10:20 am
I use CAD.
OK thx. Can't reproduce using this same style. :?
Could you try hard resetting your FC preferences by renaming %APPDATA%\FreeCAD folder (need to do it with no FC instance running) ?
thyssentishman
Re: Sketcher CreatePolyline mode cycle shortcut
openBrain wrote: Wed Jul 06, 2022 10:27 am Could you try hard resetting your FC preferences by renaming %APPDATA%\FreeCAD folder (need to do it with no FC instance running) ?
Done! With default preferences it works as expected. What preference could be interfering? I don't set any shortcuts manually that could override this.
Kind regards,
Johannes
openBrain
Post by openBrain »
thyssentishman wrote: Wed Jul 06, 2022 10:33 am Done! With default preferences it works as expected. What preference could be interfering?
Unfortunately not a lot of clue from my side ATM...
I would have think to that also.
Can you check in the (previously failing) "user.cfg" file and search for a group identified with <FCParamGroup Name="Shortcut"> :?:
If it exists, you can have a look or copy it (the whole group) here. ;)
thyssentishman
openBrain wrote: Wed Jul 06, 2022 10:40 am Can you check in the (previously failing) "user.cfg" file and search for a group identified with <FCParamGroup Name="Shortcut"> :?:
It doesn't exist. Would you like to have the whole file?
Kind regards,
Johannes
openBrain
Post by openBrain »
thyssentishman wrote: Wed Jul 06, 2022 10:46 am It doesn't exist. Would you like to have the whole file?
Why not. Just to see if we can reproduce with it. Please check there is nothing confidential in it before posting, such as names appearing in MRUs or so. ;)
thyssentishman
openBrain wrote: Wed Jul 06, 2022 10:47 am Why not. Just to see if we can reproduce with it.
Good news, I found the problem. It was indeed my fault. I forgot I had created a shortcut for a macro (M,O) that was interfering. Good to know at least that the CreatePolyline tool will still work if its shortcut is overridden.
It would be nice to have a feature that keeps track of default shortcuts and warns you about overriding them.
Sorry if this was a waste of your time and thank you for your help @openBrain and @drmacro.
Kind regards,
Johannes
