Page 1 of 1
Splash screen shadow problems - Picom at fault
Posted: Fri Jul 01, 2022 3:48 pm
by ifohancroft
I love the new splash screen and the fact that it has transparent parts, however, in-order for it to look its best, you need to tell your compositor to not draw shadows around the window.
I edited my compositor's config (Picom) to tell it to not draw shadows around windows of type 'splash' and to my surprise, that didn't remove the shadow, so I started trying all possible value types, in-order to find one that works. To my surprise, neither of the values worked.
TL;DR: FreeCAD's splash screen either uses the wrong window type, or doesn't set one at all. Its window type should be 'splash'.
OS: Manjaro Linux (MATE/mate)
Version: 0.21.29321 (Git) AppImage
Hash: 8ee773362e08d703bce9cfdcefd8e4ad424a7d44
Python 3.10.5, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
* MechanicalKeyboards
* sheetmetal 0.2.49
* kicadStepUpMod 10.12.4
Re: [BUG] Splash screen either uses the wrong window type or doesn't set one at all
Posted: Fri Jul 01, 2022 5:35 pm
by adrianinsaval
use xprop to check what type it has, I agree it should be of type splash
Posted: Fri Jul 01, 2022 6:00 pm
by ifohancroft
adrianinsaval wrote: ↑Fri Jul 01, 2022 5:35 pm
Good call.
Here is the output:
XKLAVIER_STATE(INTEGER) = 0, -1316051456
WM_STATE(WM_STATE):
window state: Normal
icon window: 0x0
_NET_WM_DESKTOP(CARDINAL) = 0
_NET_WM_STATE(ATOM) = _NET_WM_STATE_SKIP_PAGER, _NET_WM_STATE_SKIP_TASKBAR, _NET_WM_STATE_FOCUSED
_NET_WM_ALLOWED_ACTIONS(ATOM) = _NET_WM_ACTION_CHANGE_DESKTOP, _NET_WM_ACTION_ABOVE, _NET_WM_ACTION_BELOW
WM_TRANSIENT_FOR(WINDOW): window id # 0x2c0000b
_NET_WM_ICON_NAME(UTF8_STRING) =
_NET_WM_ICON(CARDINAL) = Icon (64 x 64):
(not shown)
XdndAware(ATOM) = BITMAP
WM_NAME(STRING) =
_NET_WM_NAME(UTF8_STRING) = "FreeCAD"
_NET_WM_WINDOW_TYPE(ATOM) = _NET_WM_WINDOW_TYPE_SPLASH, _KDE_NET_WM_WINDOW_TYPE_OVERRIDE, _NET_WM_WINDOW_TYPE_NORMAL
_XEMBED_INFO(_XEMBED_INFO) = 0x0, 0x1
WM_CLIENT_LEADER(WINDOW): window id # 0x2c0000b
WM_HINTS(WM_HINTS):
Client accepts input or input focus: True
window id # of group leader: 0x2c0000b
WM_CLIENT_MACHINE(STRING) = "battlestation"
_NET_WM_PID(CARDINAL) = 17556
_NET_WM_SYNC_REQUEST_COUNTER(CARDINAL) = 46137361
WM_CLASS(STRING) = "freecad", "FreeCAD"
WM_PROTOCOLS(ATOM): protocols WM_DELETE_WINDOW, WM_TAKE_FOCUS, _NET_WM_PING, _NET_WM_SYNC_REQUEST
WM_NORMAL_HINTS(WM_SIZE_HINTS):
user specified location: 2680, 417
user specified size: 400 by 245
window gravity: NorthWest
I am not entirely sure what the window type is, because it has '_NET_WM_WINDOW_TYPE_SPLASH', but it also has '_KDE_NET_WM_WINDOW_TYPE_OVERRIDE' and '_NET_WM_WINDOW_TYPE_NORMAL'.
Posted: Fri Jul 01, 2022 6:04 pm
by adrianinsaval
do you have issues with some other program's splash? looks like it is actually set a splash
Posted: Fri Jul 01, 2022 7:40 pm
by ifohancroft
adrianinsaval wrote: ↑Fri Jul 01, 2022 6:04 pm
You are right. The shadows are visible on other programs' splash screens as well. I guess the problem is either on my end or with Picom itself.
P.S. I haven't posted a bug post in here in awhile and I don't see a way to close the thread - what should I do?
Posted: Fri Jul 01, 2022 7:56 pm
by adrianinsaval
Usually prepending [solved] to the title is enough, in this case it's not really solved so it might not be appropriate, but please edit the title to specify it's a in issue with picom and remove the [bug] part since it's not a bug in FreeCAD, in general it's best not to put [bug] in the title until you have confirmation that it is a bug
Posted: Sat Jul 02, 2022 12:31 am
by ifohancroft
adrianinsaval wrote: ↑Fri Jul 01, 2022 7:56 pm
Thank you!
