Manipulator WB - Annotation plane
Hello
I am looking for info about Annotation plane used in Manipulator WB.
For example how is created or selected.
Thanks in advance.
Thanks in advance.
Re: Manipulator WB - Annotation plane
Hi @manos
I've pushed a fix for the Annotation Plane.
to use it in Caliper, check the Annotation plane before starting to measure and click on the dynamically added plane
EDIT:
The fix is adding an issue:
16:45:21 <Exception> Access violation
16:45:21 1e-07 Selection.cpp(150): Unhandled Base::Exception caught in selection observer:
Hi @easyw-fc
Thanks again but how shall I use this fix ?
1) just update the Manipulator WB through FC Tools Addon manager
2) have a look at here
https://www.forum.freecadweb.org/viewto ... 73#p293173
@easyw-fc I updated the Manip. WB
I would like to ask if it is possible to measure the distance between two points located at different bodies which are inside the same Std Part container.
Sorry I forgot it.
- test 2022-07-01.FCStd
- (22.58 KiB) Downloaded 10 times
