i like it. how long does it take?
Challenges?
- thomas-neemann
Re: Challenges?
- Shalmeneser
Re: Challenges?
Less than 10 min.
The pocket via DatumPlane didn't want to be PolarPatterned.
- thomas-neemann
Re: Challenges?
Challenge 14.08.2022
what is the fastest method (also non-parametric) to create a 3d model from this 2d-dxf file?
Re: Challenges?
This is a hell of a job to do.
I started making 3 separate Parts for Top Front and Side and moved the shapes into that Parts.
Next is moving the Parts to the right position. Now I stop to enjoy the good weather and continue later.
If someone else want to continue you can take my file
- Challenge14aug.FCStd
- (700.72 KiB) Downloaded 15 times
- thomas-neemann
Re: Challenges?
thanks for the cooperation.
a lot is symmetrical. I assume it's less than 10 minutes. I'm in the process of doing it
Re: Challenges?
In my opinion the best method is to make lines in Draft for half the model using Snap.
Redraw the lines with a Wire.
The Wire can have a standard fillet.
Make a circle and sweep that over the Wire
Use a mirror to complete the frame.
Only superman can do that in 10 minutes
- thomas-neemann
Re: Challenges?
yeah, i'm doing something like that right now. I've had a few mistakes. an experienced freecad user could do it in less than 10 minutes. the video with all wrong ways cut out will probably be less than 10 minutes
that's how far i'm at now
edit
here ist the result. i will make a video
- thomas-neemann
Re: Challenges?
here is my suggestion. a video of about 5 minutes. an experienced freecad user can do it in less than 10 minutes
https://www.youtube.com/watch?v=uyiWvBapevQ
- papyblaise
Re: Challenges?
good nap
- sieste.FCStd
- (910.54 KiB) Downloaded 16 times
- sieste.JPG (20.24 KiB) Viewed 778 times
- thomas-neemann
Re: Challenges?
the workflow is suitable for something like that, how long would it take for an experienced user
