Fasteners <class 'Base.ParserError'>: syntax error
PAS_Drafter
Post by PAS_Drafter »
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * Assembly4 0.11.10
  * Curves 0.3.0
  * ExplodedAssembly
  * fasteners 0.3.38
  * Manipulator
  * MOOC 2022.4.21
  * OpticsWorkbench 1.0.8
  * sheetmetal 0.2.49
  * ToolViewReverse_ToolBar
I've started running into this problem in v.20 with the latest version of Fasterner WB. I can import the bolt want (ASMEB18.5.2) with no problem. I then set the diameter and the length using the drop down in the Parameter's section (1/2" and 1 1/2" in my case). I then adjust the position of the bolt to where I want using the Placement dialog. At this point everything works as expected and I have no problems. However, later when I come back and decide to change the diameter or length I start getting and "!" on the part and it gives me an error "Syntax Error" when I put my cursor over it. The console gives me
09:01:40  Traceback (most recent call last):
  File "C:\Users\PS Tech 01\AppData\Roaming\FreeCAD\Mod\fasteners\.\FastenersCmd.py", line 153, in execute
    fp.lengthCustom = l
09:01:40  Recompute failed! Please check report view.
I've tried renaming things, changing sizes, but nothing I've done seems to get rid of the error. I end up having to delete the bolt and bring in another one and it will work fine again.
Has anyone else run into this?
Syres
Re: Fasteners <class 'Base.ParserError'>: syntax error
Post by Syres »
The current version of Fasteners is v0.3.45 not 0.3.38 quoted in your post, the fix could well be in those commits.
PAS_Drafter
Syres wrote: Thu Jun 23, 2022 4:53 pm The current version of Fasteners is v0.3.45
DDDOOOHHHH!!! :oops: :oops: :oops:
I forgot I'm working on a different computer that I just updated FreeCAD to .20. On my other one I had updated all the modules, but forgot to go in and have it update the ones on this one after the update.
Thanks for the catch. I'll see if that solves things.
On a side note, I did manage to get the error to go away. After reading the error again (I'm not real familiar with the FreeCAD code) but I noticed the variable name it was referencing was
fp.lengthCustom = l
. So I went in cleared any data and/or any automatic settings in that field and reset the bolt size using the drop down again. It started working after that.
