Using Additive Pipe on sections of a path?
I'm trying to do like a partial or "section-ed" sweep to generate "teeth" on the bottom of this stage to help grab the base of this headphone stand, but instead of sweeping the entire path of the base and then pocketing to get the four tabs, I'm hoping to run an Additive Pipe on the for line sections. But it doesn't seem to work properly.
Any suggestions on how to do this in an elegant way?
Trying to sweep these "teeth" on the four lines here, but it only sweeps on one. I know I can close the path and then do pockets to get the teeth, but it just seems like an inelegant solution: Here's my file.
- Shalmeneser
Re: Using Additive Pipe on sections of a path?
PartDesign_AdditivePipe :
(but a loop then a cut is a logic method.)
BTW, you could draw the Sketch.tooth using the sketch origin THEN Map mode this sketch to the path.
The path must a single line.The cross-sections must not contain disjoint or crossing loops.
- Pipe Origin _SHALM.FCStd
- (15.71 KiB) Downloaded 12 times
- Shalmeneser
* You should try not to use sketch upon face : TNP (Topological_naming_problem)
* Sketch016 is weird. Dimensions should be : 184, 189, 42.
- papyblaise
you have 2 straight clips and 2 curves, you can (as you propose) make the whole crown and Pocket the 4 parts to remove (make one and multitransform)
or do 1/2 and Rotate
- headphone.JPG (12.27 KiB) Viewed 852 times
- headphone.FCStd
- (279.09 KiB) Downloaded 6 times
Thanks, I guess it's as I feared, but mapping to path origin will make it simpler.
Placing bits like this is nicely done with Latice2 workbench.
A video conveniently describes the process:
https://youtu.be/aNVeBgMorj0
- Lattice2_lid_clips.png (295.65 KiB) Viewed 814 times
If this was mold work I would be thinking about what is the best approach to use if I later (5 years from now) need to move one of the latches 1mm and slightly modify the profile. So I would probably model 4 (1 sketch 1 pad) and place them explictly. It's not as fun as a sweep but easy to modify and latches always seem to be the "can we change that" item.
This seems to work only if all the latches are the same shape.drmacro wrote: ↑Mon Jun 13, 2022 1:18 pm Placing bits like this is nicely done with Latice2 workbench.
Technically, two of my latches should be curved, and the other two flat, but practically I can use flat latches for all four points to achieve my goals.
Thanks.
Hmm...just make two sets of latches.StarlessCaviar wrote: ↑Tue Jun 14, 2022 5:51 amThis seems to work only if all the latches are the same shape.drmacro wrote: ↑Mon Jun 13, 2022 1:18 pm Placing bits like this is nicely done with Latice2 workbench.
Thanks.
Just to follow up. Here is an example of multiple latch types done with Lattice2:StarlessCaviar wrote: ↑Tue Jun 14, 2022 5:51 am ...
Thanks.
- Lattice2_multipl_retaining_tabs.FCStd
- (88.1 KiB) Downloaded 9 times
