I am trying to do a simple step that causes an error in FCAD v 0.19.24267 but no error when I try in Fcad v 0.18. FCad v0.19 file attached.
The error is caused when I try to convert a Wire into a BSpline in DRAFT Wb.
Error in Report View:
13:24:47 Running the Python command 'Draft_WireToBSpline' failed:
File "C:\Program Files\FreeCAD 0.19\Mod\Draft\draftguitools\gui_wire2spline.py", line 79, in Activated
super(WireToBSpline, self).Activated(name=translate("draft","Convert polyline/B-spline"))
File "C:\Program Files\FreeCAD 0.19\Mod\Draft\draftguitools\gui_base_original.py", line 117, in Activated
App.activeDraftCommand.finish()
File "C:\Program Files\FreeCAD 0.19\Mod\Draft\draftguitools\gui_splines.py", line 163, in finish
old = self.obj.Name
Cannot access attribute 'Name' of deleted objectTraceback (most recent call last):
File "C:\Program Files\FreeCAD 0.19\Mod\Draft\draftutils\todo.py", line 141, in doTasks
f()
TypeError: _removeSwitch() missing 1 required positional argument: 'switch'
13:24:47 ToDo.doTasks, Unexpected error:
<class 'TypeError'>
in <bound method Tracker._removeSwitch of <draftguitools.gui_trackers.bsplineTracker object at 0x0000020B407ABBE0>>(None)
All advice is appreciated. Thx.
OS: Windows 10 Version 2004
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Hash: 476ecf091941bead59b14e44afa6064d5a66afa3
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
[solved] Draft WB Wire to BSpline causes TypeError _removeSwitch()
- miniellipse
- freecad_error_draftguitools.FCStd
- (9.7 KiB) Downloaded 25 times
Re: Draft WB Wire to BSpline causes TypeError _removeSwitch()
No such error in 0.20, try with dev version.
OS: Windows 10 (10.0)
Version: 0.20.28193 (Git)
Python 3.8.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
- miniellipse
[solved] Re: Draft WB Wire to BSpline causes TypeError _removeSwitch()
Sorry to bother you all. But I solved with a clean re-install of 19.4
