Display of constraints: some are missing
I have this sketch:
However, when I zoom in, they are not all shown again: They remain hidden until I touch one of the lines of the sketch or one of the axis lines; here I just hovered over the upper horizontal line (excuse the size, the screenshot is taken with a different tool to show the mouse pointer): .
All this hiding and showing takes place only if there are more than one constraint associated with a certain point.
I have already a confirmation from a Ubuntu user , copied here for convenience, and I would like to see a confirmation from Windows as well.
Ubuntu:
OS: Ubuntu 20.04.4 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.
Branch: unknown
Hash: 663d4fe93a49053d3bbdf94061b6093e28cf8897
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, OCC 7.5.2
macOS:
OS: macOS 10.16
Version: 0.20.27770 (Git)
Python 3.9.10, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: C/Default (C)
Installed mods:
* FC_SU
* ThreadProfile
* .DS_Store
* DynamicData
* FeedsAndSpeeds-master
* fcgear
* A2plus
* Manipulator
* fasteners
* CurvedShapes
* sheetmetal
* ExplodedAssembly
* Curves 0.3.0
* Assembly4
When I zoom all out some constraints are hidden, probably to not croud the display too much. That is ok.However, when I zoom in, they are not all shown again: They remain hidden until I touch one of the lines of the sketch or one of the axis lines; here I just hovered over the upper horizontal line (excuse the size, the screenshot is taken with a different tool to show the mouse pointer): .
Ubuntu:
Version: 0.20.
Branch: unknown
macOS:
OS: macOS 10.16
Installed mods:
* FC_SU
* ThreadProfile
* .DS_Store
* DynamicData
* fcgear
* A2plus
* Manipulator
* fasteners
* CurvedShapes
* sheetmetal
* ExplodedAssembly
* Curves 0.3.0
* Assembly4
- hidddenConstraints.FCStd
- (3.74 KiB) Downloaded 31 times
- thomas-neemann
Re: Display of constraints: some are missing
Sorry! Done, attached to the post above.
Confirm the same experience using either 0.20 or Link branch.
Bit of a PITA having to search for constraints on the list rather than in the sketch
Strangely the common denominator so far seems to be OS?
Mine is also Ubuntu 20.04.4 LTS based...
correction:
just tried in Win10
same behaviour
later edit:
your file chrisb behaves exactly as described....
correction:
just tried in Win10
same behaviour
OS: elementary OS 6.1 JAlnir (Pantheon/pantheon)
Version: 2022.111.30764 (Git) AppImage
Branch: LinkDaily
Hash: ef3092bcbca5475eff4eb7ff7933eb3e9bbbe4b9
Python version: 3.9.9
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
- thomas-neemann
everything is always displayed for me, only pushed together in time, if I simply continue working, everything jumps back to the right place. it's not a problem in my opinion
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.27936 (Git) AppImage
Branch: (HEAD detached at 66f3474)
Hash: 66f34746c8e8e2b18f308d705b6a98d9d6942791
Grouping constraints on zoom out happens every time. Ungrouping happens only on highlighting entities. Could this be the programed behavior?
Zoom all out. Then hover over some geometry of the sketch. That should hide some constraints. Now zoom in again -> they remain hidden as described above.
Maybe, but in the second image it seems as if there are no constraints shown for the upper right point.
I was wrong in my previous observation. On zoom out grouping again happens only on highlighting a geometry item.
Here the unnumbered horizontal and vertical constraints are grouped to pre other ones with an empty string before/after the comma.
As in the arcs left point? The POP tangency there is grouped with the other POP tangency since they are the same type.
