I am new to FreeCAD. An enormous undertaking, for which I am grateful to the community.
I find it very difficult to get FreeCAD to work properly. I have watched many tutorials and have tried many different techniques to accomplish the same goal (cutting screw holes in a fusion object). They either don't work altogether, or mess up something that was fine before.
Firstly, what do the Red check symbols and the White on Green down arrows in the Model tab of the Combo View mean?
Secondly how do I make the "Graph a DAG"?
Third, Is it possible to cut pockets in a fusion object, or do I have to cut them in each components separately? Can I do it in each component after fusing, or do I have to do it before?
Why doesn't the spacebar always work on selected items to make them visible/invisible?
Appreciate any responses.
OS: Windows 10 Version 2009
Version: 0.19.24267 +99 (Git)
Branch: Branch_0.19.3
Hash: 6530e364184ce05ccff39501e175cf2237e6ee4b
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
What do Symbols mean
- Shalmeneser
- Shalmeneser
- Shalmeneser
Re: What do Symbols mean
Minimal working example ?Third, Is it possible to cut pockets in a fusion object, or do I have to cut them in each components separately? Can I do it in each component after fusing, or do I have to do it before?
MWE (Minimal Working Example) is a file that show the problem.
You could have different way do things, usually a cut in a fusion is doable, but if a "fusion" is not a fusion or have some error on it, probably FC could nit do the job.
So an example that show what is done wrong is very welcomed.
Regards
Carlo D.
Regards
Carlo D.
- Various other stuffs.
The error that it must be a DAG means you have some circular dependency. A depends on B, which depends on A. A cannot be recomputed because B is not yet recomputed and B cannot be recomputed because A cannot be recomputed because B cannot be recomputed because A cannot be recomputed...
Also which workbench are you using? Some of what you say looks like you might be talking about Part WB but I also suspect you might be using PartDesign WB.
If you are actually modelling the threads, then there are some tricks you need to consider, like the profile being swept along a helical path must be of a size and shape such that the solid created from the sweep does not intersect itself. You also need to ensure that the path that the profile is to be swept along does not begin at the same point as a splitter edge in a cylinder begins.
Thanks for all the help.
When I referred to screw holes, I meant smooth cylindrical holes. I tried many different techniques using the "Parts Design" workbench. Using the pocket tool always distorted the entire object. Then I tried unfusing the object, then using the the "Part" wb and did a boolean subtract of a cylinder, which worked for one. When I tried to use the array or pattern tools the first hole disappeared and there were no new ones, (if I tried to cut the holes before creating the array or after) I finally cut each hole individually in each component using the "Part" wb.
Attached is the completed file. Sorry l didn't save and send the messed up ones.
- NesproUCHolder4Holes 3mm.FCStd
- (58.19 KiB) Downloaded 44 times
