I am trying to design a sheath for a pair of scissors to stop them poking a hole in my pocket. My design is an elliptical hollow cone but I'm having a lot of difficulty making it.
So I am starting with a solid ellitical cone and will 'subtract' a similar one once I have sorted out how to do it.
Half of the solid cone seems to be OK but the other half doesn't. What am I doing half wrong?
Thanks for any help - it's much appreciated.
OS: Windows 10 (10.0)
Version: 0.19.23141 (Git)
Hash: 0eba78d40096720f7a637a9a73c382a08b820bca
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Using Loft
Re: Using Loft
A loft transforms one shape to another. It would appear the model represents a sweep of some sort.
A sweep takes as input a profile and a path. A triangle is not a suitable path.
I suggest you refer to the wiki.
Re: Using Loft
Would the following design be useful to you?
ellipse dimensions:
major: 6mm
minor: 3mm
distance from origin: 120 mm
thickness: 2mm
if you want, you can change all the dimensions according to your wishes
ellipse dimensions:
major: 6mm
minor: 3mm
thickness: 2mm
- makas kılıfı.png (256.93 KiB) Viewed 1023 times
- ScissorSheath.FCStd
- (125.56 KiB) Downloaded 63 times
Re: Using Loft
I found this video very helpful on explaining lofts: https://www.youtube.com/watch?v=jP5dCB6FDpo
Maybe you already know how to use it.
