after a while - and because the BIM model for our house is trickling in, I had an updated look on it via FreeCAD.
Unfortunately, I have yet to find an aspect that 0.20-24693 does better than the last version I reviewed.
Importing an IFC from Archicad works (quite well), but contrary to 0.19-23141 the 0.20-24693 is unable to make objects translucent.
Yeah - "The X-ray doesn't work" is about as precise a bug report as it gets. As in 0.19-23141 it "just works". - worsening
I'll try the stable 0.19-24276 too, to see if that has fewer regressions.
also didn't work "Fetching release information for tag "0.19_pre" from GitHub API.
GitHub API request failed!" - did certainly work up to 0.19-23141. I guess the tag has changed.
after the release of 0.19 we switched from travis to github-actions to create the bundles. In addition the name was changed so we can use the same name after a release. So hopefully in the future, we do not have to discontinue the updating process.
