Pocket command fails
Today's project was going fine until
I have redrawn both of these with no change in outcome. Both sketches are fully constrained.
Sketch002 in 'End Relief' worked perfectly. I know of nothing that's different - nothing that would stop the 'Pocket working.
What have I fouled up?
Thanks
my second 'Pocket' command (Sketch003) failed. The next one (Sketch004) failed too.I have redrawn both of these with no change in outcome. Both sketches are fully constrained.
Thanks
- A-Frame Airbag Jig.FCStd
- (299.33 KiB) Downloaded 43 times
"It is much harder to simplify than to complicate."
Joseph Kimble
Joseph Kimble
Re: Pocket command fails
Hi Vagulus,
What version of freecad are you using? It is requested that you copy that data before posting query .
I just downloaded you file and it is working for me to pocket using Sketch003. In ver 0.19
Have you checked that is working in the correct direction? Ie you may need to select the option for reverse in the pocket.
Thickness broke your solid, do it another way....
- papyblaise
At home it work perfectly , try "Reverse"
- box.FCStd
- (559.5 KiB) Downloaded 34 times
- box.PNG (40.55 KiB) Viewed 1067 times
If a PartDesign feature or Part boolean doesn't work, use Part->CheckGeometry on the things it is based on. Thickness is a picky operation and it shows errors as Bance pointed out.
Nevertheless it works here, but I would not really rely on a model showing errors.
OS: macOS High Sierra (10.13)
Version: 0.19.22164 (Git)
Hash: f2a9f712e8d68ee2393d0fe748c02096c4148a32
Python version: 3.8.5
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
Qt version: 5.12.5
OCC version: 7.4.0
I may add something concerning stability: You may have read that sketches should not be mapped to faces, so you created a DatumPlane. However, this doesn't help if the DatumPlane is mapped to a face.
What should I do then?
Joseph Kimble
Joseph Kimble
I thought I was confused before but it's worse now.
I cannot find any Part->CheckGeometry function. I must be looking in the wrong place but I thought I have tried everywhere. Where is this functionality available?
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: English/NewZealand (en_NZ)
Joseph Kimble
Joseph Kimble
Have a look at this page, especially the paragraph about creating stable models.
Part workbench->Menu->4th block->6th entry.
I select the Part Workbench but I can't find any Menu->4th block->6th entry. I'm afraid that I'll have to ask you to be very patient and post images of the buttons. I have tried all the buttons and drop-down menus and I can find nothing. It can't all be written off to my eyesight failing with age.
Remember that I am using
OS: Windows 10 (10.0)
Version: 0.19.22209 (Git)
Hash: 9c3f9b72a82249d5fcf1f543dd69a78740251b26
Python version: 3.6.8
Qt version: 5.12.1
Locale: English/New Zealand (en_NZ)
The interface is different from version 18. It has a bigger cross-hair cursor (which is great) but all the buttons at the top are greatly enlarged so you have to use the MORE arrows to get at many of them. Can the size of those be adjusted too?
Joseph Kimble
Joseph Kimble
