HowTo: Dynamic length "to boundary"
Question abut PartDesign and A2Plus.
What to do if I need to make parametrized model, where the length of beams, rods, profiles - changes together with guidelines?
Is there an easy way?
would be great, if A2Plus allowed to "unlock" certain dimensions of imported parts - for auto-adjustment.
- HowTo_Dynamic length_to boundary_Straight.FCStd
- (26.45 KiB) Downloaded 73 times
- Body.FCStd
- (14.84 KiB) Downloaded 58 times
Re: HowTo: Dynamic length "to boundary"
Bance, this is what i already know. But now looking for another, more click-able solution.
to avoid using formulas.
BoundBox in Lattice Wb. maybe could help you.
- Capture.JPG (15.88 KiB) Viewed 1830 times
DrMarco, Bance...
It is clear for me that:
1. GOTO Guides.FCStd.Sketch.Constrains -> make a reference constraint for each size (eg. 20 sizes)
2. DynamicData or Spreadsheet -> Get data from these constrains (eg. 20 reference constraints )
3. make a file-per-size or file with multiple details one-per-size with needed detail for each size (eg. 20 details - 20 full-sycle operations, not just "clicks")
4. Import details to assembly in Guides with A2P respectively from files or from one file (one-at-a-time) (eg. 20 imports)
// or maybe even create multiple complex bodies in the same file with guides.
per 20 details - min=60 / max=80 full-cycle operations
This is clear.
But what I would like to have, is:
1. Make a "template-file" with detail, mark fixed and changeable sizes (1 operation)
2. Make an Assembly file with guides (Sketch / Draft) and set guides to the fixed position as an "initial object" (eg. 20 sizes)
3. Import multiple details from the same "template-file" or just make copies in the same file of assembly (eg. 20 sizes)
4. Constrain each detail to the guides: the changeable size: vetex-to-vertex/vertex-to-edge/vertex to line (eg. 20 sizes)
=> get the size adapted to the guide line.
Then just export to the Tech draw and get a spreadsheet of detail - size.
per 20 details - max 60 full-cycle operations, min - 40 operations+20 clicks
The difference per 20 details is min 20, max 40 full-cycle operations.
Counting each operation at average a minute: this job is done either in min=30 or in max=80+ minutes
Actually 30-40 minutes ot 1.5-2 hours.
This is clear.
I do not know the intended workflow. But how about creating an array with oversized elements and then using Part_Cut?
Maybe this is an interesting example to study:
https://forum.freecadweb.org/viewtopic.php?f=24&t=49165
- Gregory son of Carl
Link objects might work here. They can update all files in one refresh and be used to create dynamic links through shape binders.
Moved to Assembly forum.
A. Link objects ? Where possible to find some explanatory?Gregory son of Carl wrote: ↑Fri Aug 07, 2020 10:28 pm Link objects might work here. They can update all files in one refresh and be used to create dynamic links through shape binders.
B. This seems to be the MAIN QUESTION over all my questions asked:
Which types of object, inter-object relations concepts are implemented/ available in FreeCAD? What are properties of them?
And where to look for descriptions?
C. May I ask here for a full list of conceptional objects and they're external/inter-object properties here?
What I forsee to prepare: for example:
SketcherObject [2D]: position[ external ], Constraints[ internal]
Constraints [dimensions, geometry relations] ::= <Type>+<?Alias>
Type ::= <Set> or <Get>
Set ::= <value>/(<formula>, <formula as reference>, <calculation of references>)
Reference ::= <to constraints in same sketch> / <constraints/properties in another object>/<values in SpreadSheet/DynamicData>
Get(reference regimen) ::= <> // makes the value available to reference, but not making it fixed
More: (what already know)
PartDesign: BodyContainer::= <Sketch>|<Pad>|<Sweep>|<Loft>|<Chamfer>|<boolean>|<DatumObject>|ShapeBinder|SubShapeBinder
//Relational properties -????
Part : PartContainer: <Sketch>|<Extrude>|<BasicShape>|<Boolean>
Draft::= ????
Arch::= ???
Other ????
And also about mentioned objects - I can not clearly understand they're properties (or was underskilled to find)
For example where to find the description of what is internal difference of
* - independent object
* - dependent copy
* - cross-reference?
Who may help?
Just now tried to make a macro, to:
-- position a certain sketch in DatumPlane at the end of Edge(in a sketch),
-- and then sweep it at selected edge.
- did not manage to, and do not know how to do. (yes this is my first try of making a macro)
Finally is there a function in FC to trim an object by plane? - instead of making a pocket at the end.
// what is the most unclear thing about FC is the certain approach to doing things.
______________________________________________________________________________________________
Else What I'd like to have: prepare a Guide not only with lines, but including lines and planes.
And to "convert" each line to a profile of choice between planes, which are at the ends of edge or crossing it.
Then workflow would look like:
1. prepare a "mesh"/model of lines and planes
2. click [FillConstruction]
3. Select of type::= <Profiles>|<sketch>|<surface>|<body> => [Profile] => profile selection poposUp (see WB-DODO)
4. Select edge -> select profile sketch -> set dimensions -> set centering -> [Enter]
=> => the selected Edge gets "converted" to profile, constrained by Planes crossing it.
5. Finally "Possibility of dream" : "explode" the model to separate details(in the same or in separate files), each auto-put to the Tech draw, with dimensions and amount. Or equally acceptable - "explode" to a set of DXF files.
