I made this sketch using Part primitives and DraftToSketch after I failed miserably with elliptical arcs in Sketcher.
Any hints on how to do it with Sketcher?
From wikipedia: "The shape of an egg is approximated by the "long" half of a prolate spheroid (ellipse around major)
joined to a "short" half of a roughly spherical ellipsoid, or even a slightly oblate spheroid".
Sketching an Egg
- wandererfan
Sketching an Egg
- egg1v02.FCStd
- (19.18 KiB) Downloaded 24 times
Re: Sketching an Egg
How about these two ellipses?
- ovoid.FCStd
- (5.55 KiB) Downloaded 24 times
- wandererfan
The segments of an ellipse are a bit difficult to constrain, because one is tempted to create a coincidence constraint of the arc's endpoint and one of the axises. But thies results in redundant constraints. So you have to use the point-on-object instead.
- papyblaise
till sketch001 all it's ok
why you don't do the rhight revolve , preaps you don't select the good axle
- egg.PNG (46.5 KiB) Viewed 671 times
and more here:wandererfan wrote: ↑Wed Aug 05, 2020 12:17 am From wikipedia: "The shape of an egg is approximated by the "long" half of a prolate spheroid (ellipse around major)
http://www.mathematische-basteleien.de/eggcurves.htm
