[Solved] Centering Substring Text
Re: Centering Substring Text
wandererfan wrote: Wed Aug 05, 2020 1:18 am
>>> s = App.ActiveDocument.ShapeString
>>> ss = s.Shape
>>> bearingX = ss.BoundBox.XMax - ss.BoundBox.XLength
I would have indeed expected that the bounding box would have the width of advance from your image, which includes some white space before the character - it is called bearing here - and some white space after the character - not named in your image.
Instead it seems that the bound box is just width wide.
openBrain
Post by openBrain »
My trick to center a ShapeString is to use an intermediate compound and some expressions.
As you use PartDesign, a ShapeBinder is needed.
I attached your file modified that way. You can change anything (cube width/length/height, shapestring text) and it will keep the text centered on the top face. ;)
d6_OB.FCStd
(97.63 KiB) Downloaded 68 times
wandererfan
Post by wandererfan »
chrisb wrote: Wed Aug 05, 2020 5:47 am I would have indeed expected that the bounding box would have the width of advance from your image, which includes some white space before the character - it is called bearing here - and soome white space after the character - not named in your image.
This is standard FreeCAD behaviour. The bound box only includes the actual shape. The distance from the reference point/origin is never included.
Advance is used to determine the position of subsequent characters.
Vincent B
Post by Vincent B »
easy with string feature of lattice2 wb:
select the face, then attach a datumpoint
call the string feature, then select datumpoint as link.
and choose middle for alignment.
the6.FCStd
(11.24 KiB) Downloaded 26 times
Kirasuna
Post by Kirasuna »
wandererfan wrote: Wed Aug 05, 2020 1:18 am You need to also allow for "bearingX" (the empty space in the "em square" before the actual shape):
EDIT: this calculation is rubbish. Don't know what I was thinking. WF
>>> ss = s.Shape
The bearingX value is determined by the font designer, and will be different for every glyph in every font.
Using this to find bearingX made it so I could account for it, thank you so much.
wandererfan
Kirasuna wrote: Thu Aug 06, 2020 1:24 am Using this to find bearingX made it so I could account for it, thank you so much.
Glad it worked for you. What I wrote is still rubbish. :oops:
The formula should of course be simplified to just use BoundBox.XMin, and it only works if the Placement.Base of the ShapeString is the origin.
I'll have a look to see if there is a way to align the reference point with the BoundBox.
openBrain
Post by openBrain »
wandererfan wrote: Thu Aug 06, 2020 2:39 pm I'll have a look to see if there is a way to align the reference point with the BoundBox.
Because of cyclic dependency, I know no more efficient way than using a Compound as I did in my above post. ;)
notSure
Post by notSure »
Vincent B wrote: Wed Aug 05, 2020 7:00 pm easy with string feature of lattice2 wb:
Thanks for this. It took me some fiddling to get this right, but now that I understand it, it is an easy solution.
