I think I have it fixed in my PR, but the PR hasn't been committed yet. The fix is only related to the recent macros stuff. If the same thing is happening with other settings the bug is probably in the implementation of those settings as opposed to a general FreeCAD bug in preferences.mario52 wrote: ↑Thu Jul 30, 2020 8:57 amnot fixedTheMarkster post_id wrote:Thanks, Mario. I think have the bug fixed now.
OS: Windows 10 (10.0)
Version: 0.19.22130 (Git)
Hash: dc65b055e5143a7d7349520da466d4d722df57e8
Python version: 3.6.8
Qt version: 5.12.1
mario
The Open Document Widget is NOT showing ALL my files
Re: The Open Document Widget is NOT showing ALL my files
Yes, I went to root, yes I opened the media folder. Like I said, there is NOTHING in the media folder when using Fcad.....Ubuntu 20.04, however, DOES show the drive I want.
I tried having Fcad open to the start screen and dragging a file from my Drive 2 into Fcad. nothing happened. I then coped THAT SAME file to the home/documents directory. I successfully dragged that file from the home/documents into Fcad and it opened.
Fcad has a problem with NOT seeing ANYTHING other than the home directory.
Maybe you can try the previous command I gave with 'True' instead of 'False'. Who knows...
nope, changing from False to True did not help.
I have also tried editing my fstab file to make me drive 2 auto mount....didn't work.
I REALLY want to get this to work as everything I can read, and the few tutorials I've used tell me this is the program I want. But, if I can't get it to MY library of files and drawings, it is useless to me. I absolutely will not clutter my home directory with data.
I can only attest to using on Linux, but, while the file open dialog does behave badly saving previously opened folders, I have files all over my network on servers, shared drives, USB drives and I can get to any of them from this dialog. So I don't get what's going on your system.Bludlust wrote: ↑Thu Jul 30, 2020 7:16 pm nope, changing from False to True did not help.
Try making a mount point in your home directory and mounting it there. Or, maybe, a link to it from your home directory?
+1drmacro wrote: ↑Thu Jul 30, 2020 7:29 pm I can only attest to using on Linux, but, while the file open dialog does behave badly saving previously opened folders, I have files all over my network on servers, shared drives, USB drives and I can get to any of them from this dialog. So I don't get what's going on your system.
So back to start. Please post your full info as indicated in the link of the red banner. We don't even know if you're using a snap, an appimage or the PPA.Bludlust wrote: ↑Thu Jul 30, 2020 7:16 pm I REALLY want to get this to work as everything I can read, and the few tutorials I've used tell me this is the program I want. But, if I can't get it to MY library of files and drawings, it is useless to me. I absolutely will not clutter my home directory with data.
I run ubuntu 18.4 inside a virtualbox vm (win 10 host) because I find it so much easier to compile under ubuntu. To access files on the host I mount the drive using the "Files" file explorer. When I click my network share it brings up a dialog where I have to enter my password, and then the contents of the network folder show up in "Files". Usually I just drag/drop the file I want over to the local /home/username/Documents folder and open it from there in FreeCAD.
But today I created a symlink to that location in the /home folder and was able to open them directly in FreeCAD.
In Files I went to the folder I was interested in (in this case c:\users\username\Documents) then right-clicked and chose to bring up a terminal here (open in terminal). This opens a terminal in that folder and displays the mount point. In this case:
/run/user/1000/gvfs/smb-share:server=hp-i7,share=users/username/Documents
I copied this to the clipboard and switched to my home folder
cd /home/username
Then inside that folder I created the symbolic link
Now I can navigate to that symbolic link and open it in FreeCAD and get to those files (after mounting in Files).
cd /home/username
sudo ln -s /run/user/1000/gvfs/smb-share:server=hp-i7,share=users/username/Documents hp_documents
OS: Ubuntu Core 16
Version: 0.18.16093 +53 (Git)
Build type: Unknown
Branch: 0.18.4
Python version: 3.5.2
Qt version: 5.5.1
OCC version: 7.4.0
I have tried creating a mount point, editing the fstab file, (which then totally denied me access to the Drive 2, as in, it wasn't even listed in file explorer. I have NOT yet created a sym link...that's next.
Build type: Unknown
Branch: 0.18.4
Qt version: 5.5.1
OCC version: 7.4.0
Out of curiosity, what's your hardware?
I don't know a lot this distro, but I know it's primary goal is to offer secure environment for IoT and embedded devices. So wouldn't that be a security lock to prevent applications to access any storage areas? Maybe there are some specific settings or flags? Or some notion of trusted applications?
At this point I think your problem is your distro.
