(SOLVED) qcad DXF help
Re: qcad DXF help
This is what you're after?
To figure out how it was done, make each step visible in turn (using the space bar) starting from the top, Sketch first then feature (Pad, pocket, whatever).
- keyboardBance.FCStd
- (136.18 KiB) Downloaded 31 times
Re: qcad DXF help
thank you so much..that looks soo good... i hope i can do something as good in time.. i will try what you say about the spacebar to view what steps you did..
thanks again i really appreciate it..
Re: qcad DXF help
ok i think i'm doing ok.. i have 1 issue that when i change the hight of the inside pads to say 5mm the guide pins on top of them change to 5mm long as well?? what have i done wrong?
the next ting i need to ask is now .. how do i add the back sketch so i can cut the ports out of the back?
thanks for you help so far it has helped alot..
Re: qcad DXF help
You are attaching sketches to faces, naughty person
You should attach sketches to standard planes, datum planes or other sketches.
They can then be offset to the correct location using attachment offset parameters in the property view.
If you use expressions they will follow any changes made to the model.
When you make your sketches you will find it beneficial to centre them on the origin, you should also make better use of geometric constraints, use horizontal and vertical to constrain elements that are linear, it will save a lot of work, trust me!
You can copy/paste the sketch into the document and then drag and drop into the body.
I've corrected some stuff in your file, look at Sketch cons_pads, see how I used hor/vert constraints to remove some distance constriants, I've also repositioned your sketches to std planes and offset them with expressions. Using proper names for features can make using expressions easier to read.
Good Luck Steve.
Good Luck Steve.
- case-pt1.FCStd
- (67.98 KiB) Downloaded 37 times
Re: qcad DXF help
thanks again..
i will look over the file and see what you are trying to teach me lol.. it's a little hard for us old farts...
thanks again..
thanks again..
Re: qcad DXF help
also another quick question.. i have some 3d's i have made of the size of the boards with parts to test the size and holes etc.. how can i colour/use these and have them stand out other than wire mode?
thanks
thanks
Re: qcad DXF help
Not sure what you mean about 3D's, can you provide an example?
Re: qcad DXF help
oh sorry i mean i have some sketches i have made to the size of the pcb's and want to use them to make sure everything aligns up ok
these are just basic ones for now.. i will make better ones later.
thanks and sorry
thanks and sorry
- keyboard-pcb.FCStd
- (8.78 KiB) Downloaded 35 times
- base pcb.FCStd
- (8.96 KiB) Downloaded 34 times
Re: qcad DXF help
To change colour Select body > RMB > Appearance
To Position select body > RMB > Transform
Re: qcad DXF help
hi sorry i didnt under stand what you were saying above?? but found this out..
https://www.xsim.info/articles/FreeCAD/ ... so-on.html
