radial holes on cylinder wall
Hi, I have a thick walled vertical pipe and I need two small radial holes down from the top and 30-degrees spread radially or lattererally. Neither hole is on a radial X/Y/Z axis of the Sketch.
I tried using a Subtractive Cylinder but when I get it out to the wall in the Z-direction (-70.0), I can't get it to rotate on the pipe center line, it wants to rotate from the outer-end of the Subtractive Cylinder and thus, no longer radial.
I searched here and youtube and only found one post from 2013 using a square block first, but Subtractive was not an option then.
How do I do this?
Thanks (if we are still talking)
OS: Linux Mint 20 (X-Cinnamon/cinnamon)
Version: 0.19.21654 (Git) AppImage
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
How do I do this?
Qt version: 5.12.5
OCC version: 7.4.0
Re: radial holes on cylinder wall
You lost me at the first sentence.
In my mind you are talking about 3 distinctly different things:
- Hole down from the top (I would say that a pipe already has a hole there...)
- Radial hole
- Hole not radial to center
create a plane and set it to correct angle then put your sketch on the plane.
you could also just create the sketch at xz plane and then rotate the sketch before doing your pocket.
here is a short video on creating planes
https://youtu.be/WdBQPXeAeMc
Thanks, but this would seem a prefect use of the Subtractive Cylinder if I can be shown how to rotate from the pipe's vertical center line and not the end of the Subtractive Cylinder. It is sittng there so close.
- papyblaise
Do additif cylinder , zen an soustractive cylinder
select a vertical plane in sketcher and do a cercle , do pocket thrue all
select polar array , do 2copy at 30°
- 2holes.PNG (17.19 KiB) Viewed 1716 times
- 2holes.FCStd
- (83.07 KiB) Downloaded 33 times
You could attach the subtractive cylinder to one of the circles on the top face of the pipe, and then adjust the rotation to 90 degrees about x or y. For the 2nd cylinder do the same and add another 30 degree rotation about z.
But this will leave you vulnerable to topological naming issue if you later change the sketch that defines the pipe in such a way that the edge you attached to gets renumbered.
Wow, thanks guys.
I will try all three and see which method seems the more simple to me.
#fosselius: You went to quite a lot of trouble and I appreciate that. Thank you.
