mesh to surface, how to do?
Hello again,
working with bones and implants the question appears: how to get a surface (FreeCAD understands) from a stl-file.
The file comes from meshmixer.
thanks a lot
thanks a lot
- grid_to_surface.FCStd
- (970.69 KiB) Downloaded 78 times
Re: mesh to surface, how to do?
This has very often been discussed: Part->ShapeFromMesh.
It doesn't produce any thing...it does create a feature in the tree, but nothing displays and error:
<Part> ViewProviderExt.cpp(1324): Cannot compute Inventor representation for the shape of grid_to_surface#H__lle_aussen002001
OS: Ubuntu 19.10 (XFCE/ubuntustudio)
Version: 0.19.
Branch: unknown
Hash: 2c56e3c9faec3accf134a2940d809dd44bcfbb3a
Python version: 3.7.5
Qt version: 5.12.4
I am using the german version the function is: part_WB -> Formteil -> Form aus Dreiecksnetz erstellen. For me this is "shape from mesh".
But no effect, even a new part in the tree without any geometrie.
It works if a solid, from meshmixer for example, is used, not in case of a shape.
It seems your intent is to convert faceted mesh into curved surface (NURBS). Right?
But this is not design intent of "Mesh to surface".
"Mesh to surface" is design to handle very simple mesh model.
What you need is "Reverse Engineering"(RE) tool.
FreeCAD has 2 RE workbench, but both limited abilities.
1. stock installed, Reverse Engineer workbench.
2. from Addon Manager, Mesh Remodel. (or something like that).
After playing with Instant Meshes and Coons surfaces in Analysis Situs:
http://quaoar.su/files/cases/autosurf01.stp
http://quaoar.su/files/cases/autosurf02.stp
- ms02.png (98.23 KiB) Viewed 2610 times
- ms01.png (130.35 KiB) Viewed 2610 times
FOSS CAD model inspection utility and prototyping framework: http://analysissitus.org
Works flawless here (tolerance 0.1), file is too big to attach, even without the FEM result: OS: macOS High Sierra (10.13)
Version: 0.19.21671 (Git)
Hash: f05253f882b336f56aae32593faa5676fd5aafdd
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
Single surface:
- ms03.png (157.25 KiB) Viewed 2598 times
- onesurf01.stp
- (59.65 KiB) Downloaded 56 times
It works in FreeCAD 0.19
Thank`s
Thank`s
- FreeCAD_019_mesh.PNG (232.34 KiB) Viewed 2579 times
Nope:
No display, but the file is 13Mb after executing Create shape from mesh...
Update: and if I load the file where it has worked from this thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=48186
It gets the same error when the file is loaded and nothing displayed...
Update: If I load the original file and set the tolerance to 0.01, instead of 0.1 it works. So why does it work at 0.1 on yours?
Version: 0.19.
Branch: unknown
Qt version: 5.12.4
