from time to time I encountered the Boolean Operations in Part Workbench don't work at all or produce unexpected results. In the last case I tried several workarounds (searching the discussions, videos, tutorials, etc), but still no success.
What I want to do:
- have a plain cylinder
- make two sets of shallow grooves to that cylinder's surface (mutually intersecting)
What I have done:
- create a cylinder
- create a sketch
- bend the sketch around the cylinder (some macro downloaded)
- extrude the sketch
- make polar array of given extrusions (lot of variations performed here to get single solid to make the Boolean happy)
- subtract this array from the cylinder
- create mirrored sketch, repeat all the (sketch-following) steps once more
What I have received:
- the first subtraction worked more or less in all conditions
- second subtraction failed everytime
Is there any way, how to do it properly?
Thank you.
Using latest 0.19 build (21514), Win64.
Part Workbench Boolean Operations
- papyblaise
Re: Part Workbench Boolean Operations
please send your file
Hello and welcome to the forum
Latest is 21775
If you provide your file more meaningful help will be given. For now I would suggest make the second set of cuts slightly deeper to avoid coplanar issues.
Check this thread for something similar https://forum.freecadweb.org/viewtopic.php?f=31&t=46525
Latest is 21775
Right, my fault, by "latest" I meant rather "nightly builds" or whatever the git binaries are marked as. I would post the file, but it's over 1M. So I'd try to sort it out.
@kisolre, this seems promising, in general the same stuff I need. Just different parametrization. Going to check it in detail.
I have tried to make the second cut deeper. After several hours of computing, it still failed.
3.54e-07 <App> Document.cpp(3732): Failed to recompute wrap_sketch#Cut001: Boolean operation failed
Cut is not a solid
RL is not a solid
Recompute failed! Please check report view.
80545.7 <App> Document.cpp(3732): Failed to recompute wrap_sketch#Cut002: Boolean operation failed
Cut001 is not a solid
RL001 is not a solid
657256 <App> Document.cpp(3732): Failed to recompute wrap_sketch#Cut002: Boolean operation failed
Cut is not a solid
RL is not a solid
Hopefully this might be used to download the design:
https://www.dropbox.com/s/x861sfuyyhkzx ... fcstd?dl=0
Tried to use the Part Design Workbench there, which is much more confusing now, but it seems like everything killing the Part Workbench also kills the Part Design one.
This seems to be a typical coplanar issue as we have seen it here with double helices. You should make one of the patterns cut a tiny little bit deeper than the other.
BTW: Why didn't you use a helix?
Though "co-planar" is named by plane. It actually includes various cases, co-plane, co-tangent-face, co-edge, co-tangent-edge, co-vertex.
To be specific, your case is a "co-tangent-face" issue, 2 helix grooves intersect at tangent faces.
In some cases, co-planar Boolean break model at one, such as your case.
In other cases, co-planar Boolean result in a defected shape, where tiny edges, selft-intersected edges, overlapped faces are hiden. These defects might break model in following operations.
