OS: Windows 10 (10.0)
Version: 0.19.19955 (Git)
Hash: fd907d6d9789f71007b8d0177d167f1de82629b8
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
I think I have followed the correct process on this, I had create several files mainly in partdesign before attempting to use assembly4 WB. So created Part container and move content of body etc for each one into each part container, and saved as separate files. Closed all file and reopened, selected the Part container and create New LCS. LCS is created but I am not prompted for any attachment properties. I have attached my files.
0.19 Assembly4 - using LCS?
- ASM_Coulter_SwingArm.FCStd
- (4.56 KiB) Downloaded 50 times
- ASM_Coulter_Bearing.FCStd
- (27.42 KiB) Downloaded 35 times
- ASM_Coulter_Arm_50RHS_6.FCStd
- (247.25 KiB) Downloaded 38 times
Re: 0.19 Assembly4 - using LCS?
Your development version is obsolete. I suggest you upgrade to a newer version. We are currently in 0.19.21320.
I'm not sure what is wrong. I poked around a bit.
There are duplicate origins in the 50RHS_6 file that I get warnings about. It won't delete them though.
Not sure how this occurred.
Just for discussion:
Later rev's of A4 now allow a regular PD WB Body to be used by adding LCS from PD WB.
So it might be a possibility to create the arm as a separate part, then create an assembly of it and the fasteners as a sub-assembly.
- ASM_subasm.FCStd
- (31.24 KiB) Downloaded 32 times
- ASM_Coulter_Arm_50RHS_6-mac.FCStd
- (110.68 KiB) Downloaded 46 times
Thanks Drmacro, for having a poke into it. I haven't got back to giving this another go as yet, but will give try what you suggest.
OS: Windows 10 (10.0)drmacro wrote: ↑Fri May 29, 2020 3:51 pm I'm not sure what is wrong. I poked around a bit.
So it might be a possibility to create the arm as a separate part, then create an assembly of it and the fasteners as a sub-assembly.ASM_subasm.png
Version: 0.19.21514 (Git)
Hash: 89ddab33f692a9bd739171689f9ab0eb58d64b35
Qt version: 5.12.5
OCC version: 7.4.0
I've only just come back to this. I'm looking for where it is possible to add LCS from the PD WB ? I've since updated FreeCAD and also the Assembly4 WB.
- Angle_LCS_annot.png (127.16 KiB) Viewed 1137 times
Thanks Dr Macro. I will get back to this and see how I go.
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.8.8
Qt version: 5.12.5
OCC version: 7.4.0
Well it's been quite some time since, but having another go at this but there seem to be some sort of offset that occurs. Files are attached if someone wouldn't mind reviewing and helping again. Thank you.
Qt version: 5.12.5
OCC version: 7.4.0
- assembly_alignment.jpg (120.06 KiB) Viewed 836 times
- (6.33 KiB) Downloaded 28 times
- ASM_Coulter_Spindle4.FCStd
- (177.79 KiB) Downloaded 30 times
- (252.4 KiB) Downloaded 44 times
