i am working with Freecad on my first document. Its a test-object often used for testing milling-machines and 3D-cad-packages.
It has worked to that point, but the next cut is not created as expected. Am i running to a barrier of maxcimum cuts there?
What can i do to create the cube with all cuts?
Many thanks
Hartmut
Problems with many Extrudes and Cuts
- wandererfan
Re: Problems with many Extrudes and Cuts
Post your .fcstd file and/or any macros you used to create your cube? Hard to tell anything from a picture and a few words.
I'm not aware of a limit on cuts.
wf
wf
I have made a solid out of all cuts and could cut deeper. But later i tried to reload the old file and could could deepter tehre, too.
So its seems to be a problem that could be solved by saving, restarting, loading ...
