Dimensioning of a Revolve
gsandy
Postby gsandy » Mon Sep 09, 2019 7:37 pm
Is there any way of adding a drawing page that shows dimensions of a revolve?
In the attached I can add a page and dimensions of the simple cube but not the revolve.
OS: Windows 7
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Locale: English/NewZealand (en_NZ)
Temp.FCStd
(49.54 KiB) Downloaded 15 times
vocx
Re: Dimensioning of a Revolve
Postby vocx » Mon Sep 09, 2019 10:09 pm
Is there any way of adding a drawing page ...
Do not use the Drawing Workbench because it is obsolete. Use the TechDraw Workbench.
gsandy
Postby gsandy » Mon Sep 09, 2019 10:18 pm
Thanks vocx, I didn't know it was obsolete.
Tried the TechDraw WB and same thing happened, the cube was OK but the "Bullet" would not work!
wandererfan
Postby wandererfan » Tue Sep 10, 2019 12:53 am
I'm going to guess that this is an OCC problem. The parallel and perspective HLR/Projection algos don't fail, but they don't return any edges either. The Coarse algo (polygon approximation) produces a reasonable result, but of course that is useless for dimensioning.
We'll have to check the shape brep with the OCC DRAW program.
Temp_noDraw_TD.brep
(191.6 KiB) Downloaded 6 times
gsandy
Postby gsandy » Tue Sep 10, 2019 1:21 am
Thanks for looking into this Wandererfan.
Postby chrisb » Tue Sep 10, 2019 2:40 am
That's rather surprising, because I get a reasonable result - despite showing an error GO::projectShape - OCC error - - while projecting shape.
Snip macro screenshot-ff80d9.png (22.72 KiB) Viewed 290 times
OS: macOS High Sierra (10.13)
Version: 0.19.18095 (Git)
Hash: 27cb54009b57c1938f7ff97026c8b35c1688233f
Python version: 3.7.3
Qt version: 5.12.1
Locale: English/Germany (en_DE)
gsandy
Postby gsandy » Tue Sep 10, 2019 3:37 am
Chrisb did you use "The Coarse algo (polygon approximation)" to get what you got? And how do you do that?
I replaced the B Spline with an Arc and got a page that I could dimension!
freedman
Postby freedman » Tue Sep 10, 2019 5:28 am
When dimensioning a revolve that was created with an arc; Sometimes in the drawing the sketch side will dimension as an arc and the revolved side can show as a b-spline and I can't get a dimension on it. It's obvious to me that OCC probably recognizes the arc on one side but the revolved side has no hard geometry lines so it just defaults to a b-spline.
gsandy
Postby gsandy » Tue Sep 10, 2019 5:32 am
Great tip Freedman, hadn't come across that yet but no doubt I would have as my drawing progressed.
wandererfan
Postby wandererfan » Tue Sep 10, 2019 12:09 pm
The first entry in the HLR Parameters section of the PropertyEditor data tab for the View.
