How to verify the direction of sketch lines?
In the Arch WB you can use a sketch as a base for a wall. The direction of the sketch lines is important if the alignment of the wall is Left or Right instead of Center. Is there a way to visually verify the direction of sketch lines?
Re: How to verify the direction of sketch lines?
In the "Elements" section of the left Sketcher panel you can switch from type "Edge" to "Start point". If you now select an element in the list it will show the start point in 3D view.
- papyblaise
Hello
No , any possibility , but an smol idea :
if you have a single vertex , rigth direction is NE/SE side , oposit is : left NW/SW
If you have close sketch (rectangle or more) right is outside , left is inside the figur
Thanks.
@chrisb:
That works. But in case of lines with a coincident constraint it is impossible to tell to which line the point belongs. Combining Edge+Start Point would be clearer.
@chrisb:
That's indeed worth a consideration, although it may be unhandy when the task is to select several points and you always have to deselect the edges.
Abdullah wrote:ping
hi
for see the begin and the end line tray this macro
(related here)
EDIT: 21/08/2019 11h18 Paris modify the code adding direction of the object (subObject) selected and the label is renamed name_subObject
ex: Sketch_Edge3_Begin ... Sketch_Edge3_End
mario
(related here)
# -*- coding: utf-8 -*-
# https://forum.freecadweb.org/viewtopic.php?f=3&t=29148
# https://forum.freecadweb.org/viewtopic.php?f=3&t=38660&p=328132#p328132
# Macro_Begin_End
# 07/06/2018 20/08/2019
import Draft
try:
sel = FreeCADGui.Selection.getSelection()
name = sel[0].Name
boundBox_ = sel[0].Shape.BoundBox
boundBoxDiag = boundBox_.DiagonalLength
#print( boundBoxDiag)
SubElement = FreeCADGui.Selection.getSelectionEx()
sbName = SubElement[0].SubElementNames[0]
print( sbName)
SubElement = Gui.Selection.getSelectionEx()[0].SubObjects[0].Vertexes
#print SubElement[0].Point
txtBegin = Draft.makeText(["Begin"],point=FreeCAD.Vector(SubElement[0].Point)) # create text Begin
txtBegin.ViewObject.FontSize = float(boundBoxDiag)/10.0
txtBegin.Label = name + "_" + sbName + "_Begin"
#print( SubElement[1].Point)
txtEnd = Draft.makeText(["End"],point=FreeCAD.Vector(SubElement[1].Point)) # create text End
txtEnd.ViewObject.FontSize = float(boundBoxDiag)/10.0
txtEnd.Label = name + "_" + sbName + "_End"
#direction of element
##SubElement = Gui.Selection.getSelectionEx()[0].SubObjects[0].Vertexes
print(SubElement[0].Vertexes[0].Point)
print(SubElement[1].Vertexes[0].Point)
direction = SubElement[1].Vertexes[0].Point.sub(SubElement[0].Vertexes[0].Point)
print( "Direction axis = ", direction)
print("___________________________________________")
except Exception:
print( "oups")
mario
Thanks Mario. The code works on Draft lines and edges of solids, but not on sketches.
Some background info:
In a sketch 'loop' segments are not necessarily connected start to end. When you use such a loop as the base for a wall somehow a single direction is determined. I am trying to understand this behavior.
hi
the macro work also with sketch (one seperate element)
or I not understand (a single direction is determined)
mario
mario
@mario52:
Ah, yes it does work. Thanks for the code and the animation.
Here is an image to better explain the issue.
The orthogonal lines in both sketches were created in a CCW direction starting with the line on the X axis.
The start point of the diagonal line in the 2nd sketch is closer to the Y axis than its end point. So its direction is opposite to the other 3 lines in the sketch.
Both walls have the Align property set to Left.
Somehow the sketch 'loop' on the right is interpreted as having a CW direction. I am wondering what logic applies here. My first conclusion was that the last element in the loop (irrespective of its position in the loop) determines the overall direction. But further experiments have shown that this does not always apply.
- Wall_Dir.FCStd
- (17.81 KiB) Downloaded 27 times
- Wall_Dir.png (11.27 KiB) Viewed 1258 times
hi
if the object is modified it is completely recalculated (new object)
mario
mario
