I need to make a much simplified model of a part (quadcopter landing gear) which has curves in 3 dimensions and I don't know how to get started.
Referring to the attached photos of the part I want to model, I am thinking a sweep is sensible but how can I prepare a path along which to sweep since the path needs to be in 3D space.
OS: Ubuntu 18.04.2 LTS
Version: 0.18.2.
Python version: 3.6.8
Qt version: 5.9.5
How to sweep along a path in 3D
Re: How to sweep along a path in 3D
This is a german post, but the images should show the idea of this technique which is sometimes referred to as "Wilfried's trick".
Thanks and good night .
Thank you both, I understand now
- papyblaise
Hello
As I see on the pictures , the 1st is only on 2 plans, aesy to do ,
and the 2cd is on one plan , very, very aesy to do too
You can merge 2 sketchs with joincurves feature (Curves Wb) together. Then you will get a 3D Path.
This is a rough starting point but all seems well - thanks again
