I'm using freecad 0.19.16718 (Git) AppImage
I created a solid with a pocket.
When creating a linear pattern feature for the pocket, specifying a number of occurrence where one projected occurrence simply touching the solid would not show up as red. This could be confusing in certain designs.
I've included a test project with a simple solid.
Instructions to reproduce issue:
1)Highlight the pocket feature in the document
2)click on "create a linear pattern" shortcut button
3)edit length=5mm
4)edit occurrences=3
Notice that the middle occurrence of the pocket is invisible. Is this a bug?
Thanks
issue: linear pattern feature for the pocket
- test.FCStd
- (11.49 KiB) Downloaded 12 times
Re: issue: linear pattern feature for the pocket
Only the non succeeding occurrences are displayed in red. If the pattern direction is the horizontal sketch axis then the second occurrence ntersects the existing body, and thus is not displayed in red. The third occurrence is outside of the body and thus is not allowed - and shown in red.
The issue is when the occurrence barely touches the solid, the solid is not noticeably changed and red is not shown to indicate that there was an affected area. I understand your explanation. What I discovered seems to be a fringe case. Don't know if this is considered a bug.chrisb wrote: ↑Sat May 25, 2019 6:02 pm Only the non succeeding occurrences are displayed in red. If the pattern direction is the horizontal sketch axis then the second occurrence ntersects the existing body, and thus is not displayed in red. The third occurrence is outside of the body and thus is not allowed - and shown in red.
Using the model you uploaded and the data given, there is a clear intersection of the second occurrence:
If you reduce the LinearPattern length to 4.999 a touching mark can be seen and the red colour disappears.
If you use my file with fully constrained(!) sketches and follow your reproducing procedure you can see that the second occurrence is showing in red as it just touches the pad.bzb.dev001 wrote: ↑Sat May 25, 2019 5:42 pm 1)Highlight the pocket feature in the document
3)edit length=5mm
- linearPatternTouch.FCStd
- (10.03 KiB) Downloaded 10 times
