Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
Hi, Just attempted my first assembly in V0.18, I had some problems adding on the A2+ workbench initially but got there in the end.
When positioning/mating two parts the properties box displayed on screen is not opening fully to enable me to delete, solve or accept the constraint, I have tried to pull the corner but I cannot expand the box, any ideas folks?
Attached clip shows what I mean.
Thanks in advance,
A2+ Properties menu.
- Con_Prop_Box.JPG (109.58 KiB) Viewed 666 times
Re: A2+ Properties menu.
Hello @un1corn,un1corn wrote: ↑Thu May 23, 2019 2:10 pm Hi, Just attempted my first assembly in V0.18, I had some problems adding on the A2+ workbench initially but got there in the end.
Thanks in advance,
i had the same problem when working on a high resolution screen with scaled text for better readability. Setting back the text scaling to 1.0 solved this problem. I will have a look at the code how the prevent the clipped dialog.
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
Please update your A2plus WB. The problem with the properties dialog should be fixed with Version V0.4.23
KBWBE
Thank you KBWBE, The A2+ constraint properties menu is now fully expanded making the lower three button accessible.
However, I had to customise the Workbenches menu and add it manually as even unzipping directly into the V0.18 'Mod' folder and restarting FC the A2+ would not show in the menu even though the Addon manager indicated it was installed.
I had no problems adding other workbenches.
Thanks again for your invaluable assist.
- A2plus_Con_Props.JPG (73.48 KiB) Viewed 545 times
