FreeCAD daily 0.18 auto constraints not working
Hi I'm used to the auto constraints, when you draw a line in sketcher and its horizontal / vertical / fixed to an object.
But for my freeCAD it isn't working any more, although it is enabled in the sketcher preferences.
Is this a bug or can I get this working again?
thnx
OS: Linux Mint 19.1
Version: 0.18.15780 (Git)
Hash: f94e76c1116ec3b818961ff65131b3d86fa5b95e
Python version: 2.7.15rc1
Qt version: 5.9.5
thnx
OS: Linux Mint 19.1
Qt version: 5.9.5
Re: FreeCAD daily 0.18 auto constraints not working
Did you try to switch it of an on? If it doesn't help you can try to reset the configuration with the button in the preferences. Another possibility is to delete your config files or to move them in case you want to restore them.
Even stranger I disabled it and now it works...
Can't confirm on Ubuntu 16.04 and self compiled Py2/Qt5 development build.
P.S. I tested with Auto constraints set to ON and coincidence was added between two lines and their points. And when set to OFF that didn't happen.
I'm experiencing a similar problem, as if auto constraints are being completely ignored.
I've tested it on Ubuntu 19.04:
* Freecad from Ubuntu repo
* App image
* Freecad Stable PPA
Also tried the PPA on Ubuntu 18.04. same behavior.
Made a screen-cast, the settings screen gets cut off in the video, there I'm going to and checking Auto constraints and applying.
Before starting Freecad, I did
Screencast: https://imgur.com/wGZM5m1
Will gladly provide more debug info.
* App image
Edit->Preferences->Sketcher
rm -rf ~/.Freecad
I've just noticed by accident that if I move to the draft workbench and return back to sketcher I
end up with two grids.
However the auto constraints have started working now.
OS: Ubuntu 19.04
Version: 0.18.1.
Python version: 3.7.3
Qt version: 5.12.2
OS: Ubuntu 19.04
Version: 0.18.1.
Qt version: 5.12.2
Please always post your full Help > About FreeCAD > Copy to clipboard info when asking, testing, or giving assistance. It helps the community/posterity troubleshoot the issue better. Thanks!
Draft has its own grid. You have to switch to Draft workbench and switch off the grid.
- la_mecanique
Exactly the same as the previous comments is happening to me. I installed 0.18.1 about 3 months ago, and have now installed 0.18.3 to the same problem: Auto constraints are not working at all after I upgraded to v18.
OS: Ubuntu 18.04.2 LTS
Version: 0.18.3.
Python version: 3.6.8
Qt version: 5.9.5
Version: 0.18.3.
Qt version: 5.9.5
Did you reset your preferences? Please note that this works only with new sketches. If it still doesn't work, try the newest 0.19 version.
