Page 9 of 11
Re: Known Issues Comments
Posted: Sat Jan 01, 2022 2:12 pm
by bambuko
chrisb wrote: ↑Sat Jan 01, 2022 1:53 pm
bambuko wrote: ↑Sat Jan 01, 2022 11:00 am
Should the info about solution to issues with nvidia drivers on Linux(ubuntu based) be added to known issues?
Yes, of course. I didn't follow all of the nvidia posts and I don't own one to reproduce. Can you make a proposal what to include in the known issues, please?
To the best of my ability (might need revising)
edited, to add forum discussion links:
OS affected - Linux, Ubuntu (and Ubuntu based distros) might affect other distros (not know at this stage)
Hardware affected - nvidia graphic cards
Problem - Freecad (tested on 0.20) crashes on loading, sometimes loads and crashes almost immediately afterwards, sometimes opens for a short time but soon crashes.
When running from terminal, might report following:
./FreeCAD_weekly-builds-26720-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD 0.20, Libs: 0.20R26720 (Git)
... clipped...
nouveau: kernel rejected pushbuf: No such file or directory
nouveau: ch5: krec 0 pushes 0 bufs 1 relocs 0
nouveau: ch5: buf 00000000 00000002 00000004 00000004 00000000 0x7f2c0812b000 0x30000 0x80000
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x46210) [0x7f2c122a6210]
/tmp/.mount_FreeCAYIY0GE/AppRun: line 41: 6296 Segmentation fault ${MAIN} "$@"
Solution - sometimes just updating nvidia drivers works, but the best/proven working option (if possible) is to change to "Use Software OpenGL" in Preferences.
Forum Discussion (links to specific posts):
https://forum.freecadweb.org/viewtopic. ... 25#p558116
https://forum.freecadweb.org/viewtopic. ... 80#p546204
Posted: Sat Jan 01, 2022 4:21 pm
by chrisb
Thanks so far!
bambuko wrote: ↑Sat Jan 01, 2022 2:12 pm
Do you want me to
link forum threads here?[/color]
Yes please; that's what I do if useful additional information can be found there.
Posted: Sat Jan 01, 2022 5:46 pm
by bambuko
chrisb wrote: ↑Sat Jan 01, 2022 4:21 pm
...Yes please; that's what I do if useful additional information can be found there.
original post edited to add links to forum discussion
Posted: Sat Jan 01, 2022 6:25 pm
by chrisb
Thanks, I added it to the known issues (with some minor layout adaptions).
Posted: Sat Jan 15, 2022 6:33 pm
by Syres
chrisb wrote: ↑Sat Jan 01, 2022 6:25 pm
ping
Is it time there was an entry at the top of Known Issues, All Platforms - Python 3.10.x and above have a known issue with Pivy see
https://github.com/coin3d/pivy/issues/88 ?
Posted: Sat Jan 15, 2022 11:32 pm
by chrisb
Is this an issue with the precompiled versions too? Do you know if a solution is in sight?
Posted: Sun Jan 16, 2022 12:04 pm
by Syres
chrisb wrote: ↑Sat Jan 15, 2022 11:32 pm
As @looo is fully aware he won't be using Python 3.10.x in the Conda recipe and the LibPack will be staying on Python 3.8.x for the foreseeable future to ensure Windows 7 still works.
As far as a solution all I can do is point to the Github issue link posted above, that's as much as I know.
Posted: Sun Jan 16, 2022 12:18 pm
by chrisb
Syres wrote: ↑Sun Jan 16, 2022 12:04 pm
Please check the top of the
Known OS specific issues . I hope it is only a transient issue.
Posted: Mon Jan 17, 2022 1:18 pm
by adrianinsaval
Note that it's not just self-compiled versions, packages from rolling release distros that have python 3.10 in their repos are of course built against that. See:
https://forum.freecadweb.org/viewtopic.php?f=8&t=65263
Posted: Tue Jan 18, 2022 10:45 am
by chrisb
I added a generic " ... and packages created by other distributions". It's not much more than making people aware of issues.
