Non programmer stuck: No module named dxfwrite
I researched this but I am confused by the answers and discussions. I am not a programmer.
I am following Yorik's "A Manual" and following exactly the instructions for the IKEA chair and the last step is DXF output but I get "No module named dxfwrite".
So can someone tell me, like I am 5 years old, what exactly do I do?
Craig, AMTELCO
Re: Non programmer stuck: No module named dxfwrite
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Craig, AMTELCO
You need to install a separate component: https://www.freecadweb.org/wiki/Dxf_Importer_Install
I followed the directions and replaced what was already there (1.39) for FreeCAD v0.16.6712.
I am following your Manual regarding "Generating 2D drawings" (IKEA chair) and on page 109:
"Our page can now be exported . . .<SNIP>
Thank you, Yorik, for responding, but that did not help.yorik wrote: ↑Tue Mar 20, 2018 1:16 pm You need to install a separate component: https://www.freecadweb.org/wiki/Dxf_Importer_Install
, which also . . .<SNIP>."The Drawing Dimensioning
workbench also features its own DXF export tool
Craig, AMTELCO
- wandererfan
Are you pushing this button:
If so, then you're using DrawingDimensioning Workbench which I believe uses this dxf library: https://pypi.python.org/pypi/dxfwrite/1.2.0.
Install it somewhere in your Python path and you should be good to go.
?If so, then you're using DrawingDimensioning Workbench which I believe uses this dxf library: https://pypi.python.org/pypi/dxfwrite/1.2.0.
I am not a programmer. Is it as simple as copying the extracted dxfwrite-1.2.0 folder to:
C:\Users\ccullum\AppData\Roaming\FreeCAD ?
Yes, exactly.wandererfan wrote: ↑Wed Mar 21, 2018 12:37 am Are you pushing this button: 32px-DrawingDimensioning_ExportToDxf.png?
Yes, exactly.wandererfan wrote: ↑Wed Mar 21, 2018 12:37 am If so, then you're using DrawingDimensioning Workbench
Ah, this was not mentioned in Yorik's manual. I have downloaded dxfwrite-1.2.0 now but do not understand installation instructions.wandererfan wrote: ↑Wed Mar 21, 2018 12:37 am which I believe uses this dxf library: https://pypi.python.org/pypi/dxfwrite/1.2.0.
Craig, AMTELCO
- wandererfan
Boy, you're really getting the bottom of the support barrel on this one - I don't use Windows, I don't use Drawing Dimensioning and I'm not a Python whiz. Never the less.....
I don't know the Windows directories, but you should have a "Mod" directory that contains a DrawingDimensioning subdirectory. I would put the unzipped dxfwrite-1.2.0 right beside DrawingDimensioning, something like this:
...Mod
......DrawingDimensioning
......dxfwrite-1.2.0
I just tried this (but on Linux) and it seems to work - at least I get a dxf file that LibreCad can open.
Thank you for you patience, wandererfan. Moving files I can deal with. I was just stumped when I saw a reference to doing a pip to install this.wandererfan wrote: ↑Wed Mar 21, 2018 8:02 pmBoy, you're really getting the bottom of the support barrel on this one - I don't use Windows, I don't use Drawing Dimensioning and I'm not a Python whiz. Never the less.....
...Mod
OMG I have not seen that term since my CP/M days.
Craig, AMTELCO
wow, I hadn't figured that DrawingDimensioning was using dxfwrite, sorry I indeed gave wrong instructions.
Basically you need to be able to do "import dxfwrite" in the freecad python console. For this, the dxfwrite folder (it must be named exactly like this, remove any number version, and check that it contains an __init__.py file), must be in one of the folders of your python search path. You get them like this in the freecad python console:
Place your dxfwrite folder in one of them.
Then check that it works with
If no error appears, everything is OK.
import sys
for path in sys.path:
print path
import dxfwrite
- wandererfan
