Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Hello i’m learning Freecad and i find the diagram of a piece , i try to make it with freecad but when i make the unión of the parts i have one piece with errors and black parts, i want to know what i’m doing wrong and how to have a single solid piece, thanks and sorry for my bad english, this is the frecad file .
Error union shapes
Re: Error union shapes
If you get an error form a booelan operation you should check the parts with Part->CheckGeometry with BOPCheck enabled. On your model there are problems with superior_pad and base_pad.
If you look at the sketch "base" it is not clear what is inside and what is outside. In fact I don't understand how this could be padded anyway. If a sketch is correct you have inside and outside. If you walk an arbitrary way from inside to outside you must always cross an uneven number of lines. From outside to outside it is always an even number of lines you are crossing. Construction lines are not counted.
Your union likely fails because you have several parts that fail geometry check using Part>Analyses geometry for errors tool (see chrisb comment).joelrodrigos wrote: ↑Fri Nov 17, 2017 4:49 pm i want to know what i’m doing wrong and how to have a single solid piece
This part is actually rather difficult to model. Your approach requires several complex sketches and Part>unions for a complete part. The preferred approach is to use many simple sketches of individual features in a sequential process using the PartDesign workbench. It is also considered good practice to fully constrain your sketches as you proceed with the process.
Rather than analyze your model I offer an alternative simpler solution using only the PartDesign workbench in the attached file:
The object of parametric modelling is to add (pad) or subtract (pocket) "features" from a starting object such as a pad. As each feature is added it is automatically unioned to the last state of the model. The pad I started with was the basic overall shape of the part as shown in the figure:
A detail of the 12 mm radius as I interpreted the drawing is also included in the figure to show the use of the required construction (blue) lines.
The rest of the features are added in the order shown in the file. Only half of the part is modeled and then Part>mirrored about the XY plane.
Due to limitations of V0.16, an edge must be created for the reference axis (green edge5) in order to use the polar pattern tool for the 7 holes as shown in the figure below. This can be done by properly locating pad014 which is later removed with pocket003.
The part is completed by mirroring it about the XY plane:
Version: 0.16.6706 (Git)
"It is a poor workman who blames his tools..."
Thanks for your advices, greetings from Peru.
Hi, and welcome! We've seen that piece in the forum before - have a look here:joelrodrigos wrote: ↑Fri Nov 17, 2017 4:49 pm Hello i’m learning Freecad and i find the diagram of a piece
https://forum.freecadweb.org/viewtopic.php?f=24&t=19934
Edit: Here's another
https://forum.freecadweb.org/viewtopic.php?f=3&t=20606
Thanks for your post, ppemawm!
Since I'm new to this cad stuff, I'm always looking for projects and the diagram Joel posted looked like fun. I really got bogged-down with that first sketch, however. Somehow I managed to get it constrained without the radius shown in the detail but it wasn't working very well. I also didn't know about Part-Mirror so I was heading down the wrong path with the rest of the project anyway.
Following the ideas in your post I successfully managed to construct the part in 0.17. I evened used a Datum line for the bolt circle.
OS: Linux Mint 18.2 Sonya
Version: 0.17.12595 (Git)
Build type: None
Hash: 8c7bb0cd551cf11551ff71d716a16211c6d5e13d
Python version: 2.7.12
OCC version: 7.1.0
It looks OK, but I need to spend some time reading about mirror as I think I need to fuse the two halves together. I'm still not that familiar with functions outside of part design.
Build type: None
OCC version: 7.1.0
Hi, I start with Reddit_02.fcstd
- in the part design workbench make a clone of Fillet002, this clone is placed outside the body
- in Draft workbench select Mirror
Thanks Willem for the pointers.
Also thanks to Bejant for links to older forum posts about this part as I didn't realize these exercises have been around for awhile. In those older posts I found a great cache of cad exercises from forum member gsegura96 at this location:
https://github.com/gsegura96/CAD-Challenge
Along with the prints of the first 14 Reddit CAD challenges, for most he also includes very nice fcstd files of the completed parts using .017 Part Design. This is great as there's not much documentation on the new features of the part design workbench. For instance, gsegura96 took a very different approach to this part than me, doing the entire part in Part Design utilizing Mirrored Feature and a few Datum Planes. There's certainly enough projects to keep me busy for awhile.
