Converting Points into a Mesh
I am a new Freecad user, but not new to CAD in general.
The difficulty that I have is that I get sent ground survey drawings with a series of points or crosses in 3d indicating their position and level. This is normally in Autocad format or dxf which I can import into FreeCAD.
I would like to convert this into a mesh so that I can more easily work with it.
Is there a simple way to do this?
Thanks
OS: Windows 8.1
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Thanks
OS: Windows 8.1
Qt version: 4.8.6
Re: Converting Points into a Mesh
Hello AndrewC.
Welcome to FreeCAD and the forum.
We had some time ago an interesting discussion in the german sub-forum about this.
You can import points with the points-workbench.
Updating to a quite recent 0.16 development snapshot und using the linked script you could convert these points to a mesh object.
Hope this helps for first steps ...
Roland
Roland
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
Roland already directed you to the correct thread, but actually to a code snippet which approximates the points with a bspline surface. This is in most cases more helpful and more viable than a mesh, but just in case you really need a mesh here is the snippet for doing so (from a few posts earlier than the one linked by roland):
This needs a recent git build / developer version or linu daily ppa.
import ReverseEngineering as Reen
points=App.ActiveDocument.terrain.Points
mesh=Reen.triangulate(points, 10000, 3.5)
import Mesh
Mesh.show(mesh)
Hi, I'm trying to do this with the FreeCAD version 0.17.10033 but it gives me the following error. What am I doing wrong?
AttributeError: 'module' object has no attribute 'triangulate'
OS: Mac OS X
Version: 0.17.10033 (Git)
Branch: (detached from f33c7b3)
Hash: f33c7b3f00f8625cf2821c23a74952d4ab671827
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 7.0.0
Thanks,
Takeo
OS: Mac OS X
Coin version: 3.1.3
OCC version: 7.0.0
Thanks,
Takeo
Apparently your Mac build doesn't link the pcl library. FreeCAD uses this algorithm to create the mesh: http://docs.pointclouds.org/trunk/class ... ation.htmlFile "<input>", line 1, in <module>
I see. It worked on my Windows 64-bit environment. Thanks wmayer.
OS: Windows 7
Version: 0.17.10031 (Git)
Hash: 0a6b382d718864b4733c58816b3fd111583499ca
OCC version: 7.0.0
Takeo
OS: Windows 7
OCC version: 7.0.0
Takeo
Same error here
AttributeError: module 'ReverseEngineering' has no attribute 'triangulate'
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
* CurvedShapes 1.0.3
* Curves 0.5.2
https://github.com/FreeCAD/FreeCAD/releases/tag/0.20
the portable..., filesize hints more batteries included...
- adrianinsaval
or just inferior compression AFAIK that one is the same as the installer. The version at https://github.com/FreeCAD/FreeCAD-Bund ... s/tag/0.20 should be a different build though.
@uwestoehr @looo does any of these builds have pcl enabled?
This thread is 5 years old. Please open a new one with a proper description what you did to get the bug.
