Why does the label not rotate with the horizontal arch axis?
bakuiseok
Post by bakuiseok »
The arch axis should be rotated horizontally and the label should be aligned with each axis line, but not so. It is necessary to draw an elevation of the building and mark the floor and ceiling of the first and second floors with lines, but there is a problem mentioned above.
And, why doesn't the number of horizontally placed axis rotate as much as it rotates horizontally? Numbers 01, 02 and so on lie to the left.
The scene I want is the same as the images below:
H-axis.FCStd
(5.47 KiB) Downloaded 19 times
thomas-neemann
Re: Why does the label not rotate with the horizontal arch axis?
Post by thomas-neemann »
bakuiseok wrote: Thu Sep 29, 2022 1:18 pm ...
if something like that should come out of it, I can shoot a video for you
H-axis-tn.FCStd
(5.55 KiB) Downloaded 17 times
bakuiseok
Post by bakuiseok »
@thomas-neemann
Can't I make what I want at the moment? I think can use Arch Grid with them.
The users of the link below seem to have succeeded.
https://forum.freecadweb.org/viewtopic.php?t=2122
bakuiseok
Post by bakuiseok »
I rotated the axis 90 degrees to the left, but it doesn't go back with the numbers in the bubble. However, when I look at the tutorial, the text rotates together just by changing the angle.
