Just an FYI, the solid created is not valid. (Using the version of the macro in Addon manager)
OS: Debian GNU/Linux 10 (buster) (XFCE/lightdm-xsession)
Version: 0.20.27078 (Git)
Hash: b836712c83556b4f30d3404e8ab9f5192979561c
Python version: 3.7.3
Qt version: 5.11.3
OCC version: 7.6.0
Sezione Dinamica
Re: Sezione Dinamica
- PlayRevolve.FCStd
- (24.79 KiB) Downloaded 94 times
While the macro is still open, in the tree view make a duplicate of the temporary object it creates (in cut mode), then close the macro. This object is a compound that contains 2 duplicate objects. Select the object, in part workbench -> explode compound. You get 2 identical objects, which explains the self-intersections of the compound.
Instead of exploding, select the object and use part union/fusion on it, you then get a valid solid.
I opened all that up so I could make one screen shot. The fails happened when the macro was completed. At least the ones shown in the report view when Cut objects is selected:TheMarkster wrote: ↑Sun Jan 16, 2022 7:42 pmWhile the macro is still open, in the tree view make a duplicate of the temporary object it creates (in cut mode), then close the macro. This object is a compound that contains 2 duplicate objects. Select the object, in part workbench -> explode compound. You get 2 identical objects, which explains the self-intersections of the compound.
Recompute failed! Please check report view.
14:47:57 <Part> ViewProviderExt.cpp(1306): Cannot compute Inventor representation for the shape of PlayRevolve#Compound: Bnd_Box is void
The section shape of your example should have 14 faces, it has 28.
So, I suppose the macro cuts both the body AND the last feature of the body.
As @TheMarkster pointed out there are 2 copies of the object in the retained solid.
It seems to me it should be the fore and aft of the cut object, rather than two copies of the aft.
Maybe something to do with the error reported when the checkbox is ticked.
Segnalo solo che l'installazione della macro tramite Addon Manager restituisce il seguente errore sul mio sistema:
Ovviamente posso fare copia-incolla del codice, ma volevo solo informare del malfunzionamento dell'installer.
17:22:51 Traceback (most recent call last):
17:22:51 File "/snap/freecad/530/usr/Mod/AddonManager/AddonManager.py", line 916, in launch_installer_gui
17:22:51 self.installer_gui.success.connect(self.on_package_status_changed)
17:22:51 RuntimeError: '__init__' method of object's base class (MacroInstallerGUI) not called.
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.21.0.31509 (Git) Snap 530
Hash: d63ac0f7f6a1bcb316eebe15ecdf23ce7dd62d4d
Python 3.8.10, Qt 5.15.5, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
Locale: Italian/Italy (it_IT)
Installed mods:
* kicadStepUpMod 10.16.8
* fasteners 0.4.52
* Curves 0.6.5
* 3D_Printing_Tools
* CurvedShapes 1.0.4
* Manipulator 1.4.9
* Assembly4 0.12.5
* fcgear 1.0.0
* A2plus 0.4.60g
* Defeaturing 1.2.0
* Part-o-magic 1.0.0
* POV-Ray-Rendering (Disabled)
* Render 2022.4.0
