Page 2 of 4
Re: Fix thumbnail preview on XDG Desktops (#4078)
Posted: Thu Nov 26, 2020 12:29 pm
by wmayer
Hooray! I got it working!
On my system I neither use the .deb packages nor an AppImage but complie FreeCAD locally.
When I tried to activate thumbnails the first time I could see that FreeCAD files got the same icon as for text documents (before it was the icon of compressed files) and that in the /tmp folder there were many files of the form tumbler-<XXXXXXX>.png that all were empty. So, this possibly was the reason why the thumbnails for FCStd files were wrong.
Additionally I now installed the packages tumbler-plugins-extra and thunar-gtkhash. And I entered this into the terminal
The most important point is to make the tumbnailer script executable for all groups, i.e chmod a+x instead of chmod u+x
Here is a list of all steps I have performed:
- Install tumbler-plugins-extra and thunar-gtkhash
- sudo cp src/Tools/freecad-thumbnailer /usr/bin/
- sudo chmod a+x /usr/bin/freecad-thumbnailer
- sudo cp src/Gui/Icons/freecad-icon-48.png /usr/share/icons/hicolor/48x48/apps/freecad.png
- sudo cp src/XDGData/FreeCAD.thumbnailer /usr/share/thumbnailers/
- cp src/XDGData/org.freecadweb.FreeCAD.xml ~/.local/share/mime/packages
- update-mime-database ~/.local/share/mime/
- sudo update-mime
- rm -rf ~/.cache/thumbnails/*
- thunar -q
Hint:
If a thumbnailer shouldn't be used and you want to show a generic icon instead then run:
xdg-icon-resource install --context mimetypes --size 64 src/Gui/Icons/freecad-doc.png application-x-extension-fcstd
This will create the file $HOME/.local/share/icons/hicolor/64x64/mimetypes/
Posted: Thu Nov 26, 2020 8:11 pm
by drmacro
I now have it working on one PC and not the other (the laptop I was trying to set up previously).
Same OS on both.
I did a diff of the files and they are all the same.
I've compared the versions on the packages in stalled on both.
Yet the desktop PC Thunar gets the preview and on the laptop it does not.
I'm stumped.
Posted: Thu Nov 26, 2020 8:16 pm
by wmayer
And did you apply
chmod a+x to the script?
In the Thunar settings make sure that thumbnails are activated. Either set it to "Always" or "Only for local files".
And in the file /var/log/syslog can you see anything about the FreeCAD thumbnailer being registered by the system?
Posted: Fri Nov 27, 2020 9:29 am
by pachiburke
Great news!
Posted: Fri Nov 27, 2020 3:48 pm
by drmacro
wmayer wrote: ↑Thu Nov 26, 2020 8:16 pm
And did you apply
Referring to the laptop where it does not work.
It appears the thumbnails are being generated. But, thunar is not displaying them. (i.e. they appear in the ~/.cache/thumbnails/)
The answers to the above questions:
- Yes, double checked
- Yes, other apps thumbnails are display
- Yes
Posted: Sun Nov 29, 2020 4:48 pm
by drmacro
This is turning out to be a real mystery.
I decided to dig into this way deeper than I want to, but now it's sort of a challenge...
I started by adding python syslog to the freecad-thumbnailer.
Then I set up file system monitoring on the ~/.cache/thumbnails folder and /usr/bin/freecad-thumbnailer file using inotify in a terminal window for each.
In addition I set up a tail -f on /var/log/syslog
On the desktop that works, when I touch a freecad file that has a thumbnail:
- access to the freecad-thumbnailer is logged by inotify
- logging from freecad-thumbnailer to syslog is seen
- additons to the ~/.cache/thumbnails (the creation of the .png) is logged by inotify
- thunar presents the thumbnail
Same setup on the not working machine:
- access to the freecad-thumbnailer logged by inotify
- no logging from freecad-thumbnailer to syslog is seen
- no additons to the ~/.cache/thumbnails are logged by inotify
It appears freecad-thumbnailer is being called but never executes.
Posted: Sun Nov 29, 2020 6:55 pm
by wmayer
Does it create empty files of the form tumbler-XXXXXXX.png inside /tmp?
Posted: Sun Nov 29, 2020 7:17 pm
by drmacro
wmayer wrote: ↑Sun Nov 29, 2020 6:55 pm
Yes, on both machines.
But, they disappear on the working machine.
Posted: Mon Nov 30, 2020 10:07 am
by wmayer
drmacro wrote: ↑Sun Nov 29, 2020 7:17 pm
This is exactly the behaviour I had too when it was not working. As a next step modify /usr/bin/freecad-thumbnailer to e.g. write some content to a file in /tmp. If this file isn't created means that the script just won't be executed.
There are two things I can imagine why:
- The script is not marked as executable
- /usr/bin/python is a symlink to the actually used Python version. Maybe the symlink doesn't exist
As a simple test execute the script manually:
/usr/bin/freecad-thumbnailer -s 128 /tmp/test.FCStd /tmp/test.png
Posted: Mon Nov 30, 2020 6:39 pm
by drmacro
wmayer wrote: ↑Mon Nov 30, 2020 10:07 am
AHA! the smoking gun.
why that symlink was not on the laptop, I have no idea.
But, fixed that and we have lift off.
Now working on both machines.
Thanks for all the help!
