PR #3794 - pad in any direction
Merged, abandoned or rejected pull requests are moved here to clear the main Pull Requests forum.
Founder
Re: PR #3794 - pad in any direction
Post by wmayer »
uwestoehr wrote: Sat Sep 12, 2020 6:58 pm
wmayer wrote: Sat Sep 12, 2020 2:52 pm When using the option Two Lengths then the length in opposite direction is incorrect.
I was not aware of this yet. I am currently abroad and will have a look Monday evening to reproduce and fix it.
https://forum.freecadweb.org/viewtopic. ... 62#p430027
jaisejames
Post by jaisejames »
If upto face can be extented to pipe connect option(in part work bench), it will be useful for multiple faces support.
uwestoehr
Post by uwestoehr »
Thanks for your fix.
uwestoehr
Post by uwestoehr »
wmayer wrote: Sat Sep 12, 2020 2:52 pm What's not working yet are the options Up to first and Up to last
I tested again and cannot reproduce this. Here is an example file:
Pad-Test.FCStd
testfile
(60.23 KiB) Downloaded 205 times
With this everything works fine:
uwestoehr
Post by uwestoehr »
OK, it strongly depends on the direction. Here another example that works:
If you change there the x coordinate to -1.000 (testfile
Pad-Test.FCStd
testfile
(142.24 KiB) Downloaded 217 times
) then "to first still works, while "to last" fails.
I have no clue yet, what causes this. I'll have a look as soon as I find the time.
Founder
Post by wmayer »
As previously said it's problem that has existed before. The point is that a ray is used to find an intersection with the nearest/farthest face and when the supposed face is too small the chance is low to find this intersection. If a custom direction is used the chance is even lower.
uwestoehr
Post by uwestoehr »
wmayer wrote: Mon Sep 14, 2020 8:53 pm The point is that a ray is used to find an intersection with the nearest/farthest face and when the supposed face is too small the chance is low to find this intersection.
I am new in this field. I just thought one goes into the pad direction and check step by step for a face. Therefore I wondered why the area of the face is important. But OK, since OCC does not support multiple bodies the pad must hit the face to form a single body.
uwestoehr
Post by uwestoehr »
Well, I see now that the limitation in finding the faces is already documented: https://wiki.freecadweb.org/PartDesign_Pad#Limitations
