Qt4/Qt5 neutral compilation fixes
Merged, abandoned or rejected pull requests are moved here to clear the main Pull Requests forum.
Founder
Re: Qt4/Qt5 neutral compilation fixes
Post by wmayer »
Nice idea. I have created a directory PySide with an empty __init__.py file and a QtCore.py, QtGui.py and for now a QtSvg.py. The contents of these files are:
QtCore.py:
from PySide2.QtCore import *
QCoreApplication.CodecForTr=0
QCoreApplication.UnicodeUTF8=1
QtGui.py:
from PySide2.QtGui import *
from PySide2.QtWidgets import *
QtSvg.py:
from PySide2.QtSvg import *
This way all the PySide code works fine so far with PySide2. Only the above CodecForTr and UnicodeUTF8 must be removed from the Python code since they don't exist in Qt5 any more.
Founder
Post by wmayer »
With git commit 23b0793a68 none of the Python modules need to be touched. So, I consider the Qt5/PySide2 migration as accomplished.
looo
Post by looo »
nice to see this is working.
triplus
Post by triplus »
And how does the import statement look like now? Continue to use the same as in PySide? Reading the documentation from Qt.py two things are documented i noticed that could have some relevance (PySide/PySide2):
https://github.com/mottosso/Qt.py
setResizeMode was renamed setSectionResizeMode in Qt 5.
I use QTableWidget (the same applies for widgets like QTreeWidget) in one of my FreeCAD related modules and have set the resize mode for header. This i guess i will have to tackle myself in the future. Not a big problem but some heads up as likely sooner or later this issue will emerge in one of the default FreeCAD modules.
https://github.com/mottosso/Qt.py/blob/ ... CAVEATS.md
This note is interesting:
Compile Qt Designer files
.ui files compiled via pyside2-uic inherently contain traces of PySide2 - e.g. the line from PySide2 import QtGui.
In order to use these with Qt.py, or any other binding, one must first erase such traces and replace them with cross-compatible code.
Does the same apply for us?
looo
Post by looo »
regarding ui files:
we are building them, so the right pyside version should be used there.
Post by Kunda1 »
BTW, any commits that are related to porting from Qt4 to Qt5 please link them to issue #2986
In the commit message you can write
issue #2968
in order to auto-link it in MantisBT. See https://freecadweb.org/wiki/tracker#Att ... o_a_ticket
