Chest of drawers
- Shalmeneser
Re: Chest of drawers
Preference > TechDraw > Scale > Vertex scale
Yes, it is about report with parts and dimensions. Some people call it cut-list and some BOM. I wasn't familiar with BOM name as well when I was creating getDimensions macro in 2017. I understand you can't share the file. But if you can test my macro with your file and give me feedback it would be nice. If you have model mainly based on Part::Cut you may try: the visibility feature, if the report is correct. Personally, for Boolean Cut I use magicCut that is able to create cut without moving objects. Just remove the common part and leave the Tree clean.Marc Bassini wrote: ↑Mon Jan 16, 2023 12:08 pm I don't know what cut-list is.
I don't know what BOM means.
This is quick, given that everything had to be done manually and parameterized.Marc Bassini wrote: ↑Mon Jan 16, 2023 12:08 pm I started it on Friday early afternoon and sent the screenshots above on Sunday at 3pm for validation.
Google told me it is French, I don't know French but I see there are a lot of variables to set.
You may want to try showAlias tool that is able to show (select) all objects with exact alias, it can be used for validation of parametric model:
Thanks
Darek
github.com/dprojects
workbench for woodworking is available at: github.com/dprojects/Woodworking
And here's a version created by one of the one-year CAP students. Unfortunately, she didn't get a good grade because she didn't finish in the allotted time (which had been extended) and some operations weren't completed. It's a real pity, because for a first piece of furniture, it's a really fine piece of work (on closer inspection, there are several slight defects, and of course I took the photo of the side with the most beautiful dovetails, but the opposite ones and those at the back weren't bad either, although they weren't quite as good; in spite of everything, it's really a great job for a beginner).
- chest of drawers.png (1013.89 KiB) Viewed 1131 times
- Shalmeneser
CAP : Certificat d'aptitude professionnelle
You are a demanding teacher, that's good, the best teachers were always the demanding ones but in the end they always let go, they didn't want to hurt anyone, thanks to such teachers you can learn more.
Thanks
Darek
Actually, I'm not. I'm just a(n old) student in a higher degree program.
