Very true. This is why ThreadMaker Macro includes disabled thread on creation, and a pair of enable/disable thread icons to act on all threads in the document. So you can design without the delay of thread computation, then enable all threads at once just before exporting project to real world. Also, have you looked at the Fastener's Workbench? It has ready-made, standardized nut and bolt objects. It could really speed up your design effort, I think.
Zombie project, or small conversion FC16->FC20
Re: Zombie project, or small conversion FC16->FC20
To get it we must want it. To keep it we must give it away. To give it away we must truly get it.
Well, this project i think is way too big for modelling threads. I will look into this in my other project though.
Time for next update: this time from group 04 - cab and walking boards:
-steps to cab:
https://para.zonk.pl/Ol49forum/fcstd/04/P430-1-0.fcstd
-walking boards and cabs floor (metal one, underneath wooden from second update):
https://para.zonk.pl/Ol49forum/fcstd/04/P483-1-0.fcstd
-angles supporting walking boards:
https://para.zonk.pl/Ol49forum/fcstd/04/P484-1-0.fcstd
- and most ambitious part so far TSUF - The Storages Under Floor:
https://para.zonk.pl/Ol49forum/fcstd/04/P488-1-0.fcstd
And assembly view of group 04 for now:
-steps to cab:
Ok, so next update, this time in two groups:
group 02:
-support for front suspension - it put some fight...
https://para.zonk.pl/Ol49forum/fcstd/02/11.13-01.fcstd
-pedestal caps
https://para.zonk.pl/Ol49forum/fcstd/02/P234-1-0.fcstd
and assembly view:
if i not missing something, then three parts left in this group....
group 04:
-some covers in cab
https://para.zonk.pl/Ol49forum/fcstd/04/P411-1-0.fcstd
-cabs door
https://para.zonk.pl/Ol49forum/fcstd/04/P414-1-0.fcstd
-walking boards supports
https://para.zonk.pl/Ol49forum/fcstd/04/P485-1-0.fcstd
assembly view:
group 02:
-pedestal caps
and assembly view:
group 04:
-some covers in cab
-cabs door
assembly view:
Todays update: group 04
-bridge between engine and tender:
https://para.zonk.pl/Ol49forum/fcstd/04/14.15-01.fcstd
-front right window
https://para.zonk.pl/Ol49forum/fcstd/04/15.16-0-1.fcstd
-support for walking boards on left side of firebox
https://para.zonk.pl/Ol49forum/fcstd/04/P486-1-0.fcstd
-support for walking board and turbogenerator on right side of firebox
https://para.zonk.pl/Ol49forum/fcstd/04/P487-1-0.fcstd
and assembly view:
-front right window
and assembly view:
So, next update:
- one part in group 02 - connector between frames and support for boiler:
(this part was hard... and still it is in quite simplified form - there should be many fillets added, but model would be too complex to handle assuming that that fillets could be done)
This file is a bit bigger...
https://para.zonk.pl/Ol49forum/fcstd/02/P211-1-0.fcstd
assembly view:
and group 04:
-windows in rear wall of cab:
https://para.zonk.pl/Ol49forum/fcstd/04/15.20-0-1.fcstd
-covers (shades?) for front windows:
https://para.zonk.pl/Ol49forum/fcstd/04/15.27.fcstd
-and finally engineer and fireman could get some rest on their chairs:
https://para.zonk.pl/Ol49forum/fcstd/04/P432-1-0.fcstd
assembly view:
assembly view:
and group 04:
assembly view:
Time for next update. Still group 04. With todays update all files from that group are converted, remains few parts newer modeled. I think i rather first convert all old files, then i will start making new ones.
-smoke deflectors on smokebox:
https://para.zonk.pl/Ol49forum/fcstd/04/14.20-3-0.fcstd
-cab doors locks:
https://para.zonk.pl/Ol49forum/fcstd/04/15.13-0-1.fcstd
-left front doors:
https://para.zonk.pl/Ol49forum/fcstd/04/15.14-0-1.fcstd
-cabs metal walls and roof
https://para.zonk.pl/Ol49forum/fcstd/04/P405-1-0.fcstd
-cabs angles:
https://para.zonk.pl/Ol49forum/fcstd/04/P406-1-0.fcstd
-and... bolts and nuts of walking boards and cabs metal floor
https://para.zonk.pl/Ol49forum/fcstd/04/P481-1-0.fcstd
and i dont't even wanna know how big that file would be if i would model all threads...
Assembly view:
-cab doors locks:
-left front doors:
-cabs angles:
Assembly view:
So next, a bit bigger update. Today group 03 - brakes. This contains all files made so far in this group. Mechanical part is mostly complete, only missing is brake cylinder and support for main lever - for first one i need to find some documentation (it is not included in engine's) for second... it is quite complicated casting. Pneumatic part have 'one' problem - same as cylinder, there is no detailed documentation for typical parts, so i would probably just draw some approximation from general drawings. So:
-position regulators for brake blocks:
https://para.zonk.pl/Ol49forum/fcstd/03 ... 2-00.fcstd
-brake blocks:
https://para.zonk.pl/Ol49forum/fcstd/03 ... 1-00.fcstd
-break beams:
https://para.zonk.pl/Ol49forum/fcstd/03/22.23.fcstd
-brake air reservoir:
https://para.zonk.pl/Ol49forum/fcstd/03 ... 02-1.fcstd
-control air reservoir:
https://para.zonk.pl/Ol49forum/fcstd/03 ... 03-1.fcstd
-main air reservoirs:
https://para.zonk.pl/Ol49forum/fcstd/03 ... -3-0.fcstd
-cylinder lever:
https://para.zonk.pl/Ol49forum/fcstd/03/P310-1-0.fcstd
-connecting levers:
https://para.zonk.pl/Ol49forum/fcstd/03/P314-1-0.fcstd
-equalizing levers:
https://para.zonk.pl/Ol49forum/fcstd/03/P318-1-0.fcstd
-brake blocks levers:
https://para.zonk.pl/Ol49forum/fcstd/03/P320-1-0.fcstd
-brake beams hangers:
https://para.zonk.pl/Ol49forum/fcstd/03/P333-1-0.fcstd
-air pump support:
https://para.zonk.pl/Ol49forum/fcstd/03/P346-1-0.fcstd
-brackets for main air reservoirs:
https://para.zonk.pl/Ol49forum/fcstd/03/P356-1-0.fcstd
-brackets for brake and control air reservoirs:
https://para.zonk.pl/Ol49forum/fcstd/03/P358-1-0.fcstd
And all of above together:
So current status:
00 - general views - nothing to do here...
01 - wheels, axes, boxes, boogies - waiting for conversion
02 - frame and suspension - two parts missing due to problems with recreating them in FC
03 - brakes - all files converted, some parts to be done after revival
04 - cab and walking boards - all files converted, some parts to be done
05 - steam engine - waiting for conversion
06 - boiler and its equipment - all files converted, many parts to be done.
07 - ash pan, jackets - not touched yet
08 - pipes, sanders, lightning - not touched yet
09 - handrails, tools, painting, misc - not touched yet
-brake blocks:
-break beams:
-cylinder lever:
-connecting levers:
-equalizing levers:
-air pump support:
So current status:
As group 03 is done for now, today group 05 - steam engine:
-crosshead guides:
https://para.zonk.pl/Ol49forum/fcstd/05/20.17-5-0.fcstd
-main piston rod sealings:
https://para.zonk.pl/Ol49forum/fcstd/05/P514-1-0.fcstd
-front support for main piston rod and rear support for sealing:
https://para.zonk.pl/Ol49forum/fcstd/05/P525-1-0.fcstd
-front covers for main piston rods:
https://para.zonk.pl/Ol49forum/fcstd/05/P526-1-0.fcstd
-main pistons and rods:
https://para.zonk.pl/Ol49forum/fcstd/05/P532-1-0.fcstd
-valve pistons and rods:
https://para.zonk.pl/Ol49forum/fcstd/05/P562-1-0.fcstd
-combination lever:
https://para.zonk.pl/Ol49forum/fcstd/05/P580-1-0.fcstd
And of course all of them (and one part from second update as well) together:
-crosshead guides:
-combination lever:
Next update, still group 05:
- bushing, side rod, third axle:
https://para.zonk.pl/Ol49forum/fcstd/05 ... 9-00.fcstd
- lubricators for main rod:
https://para.zonk.pl/Ol49forum/fcstd/05/20.27-1-0.fcstd
- main rod:
https://para.zonk.pl/Ol49forum/fcstd/05/P544-1-0.fcstd
- main rod, rear bushing:
https://para.zonk.pl/Ol49forum/fcstd/05/P545-1-0.fcstd
- side rod, front part
https://para.zonk.pl/Ol49forum/fcstd/05/P550-1-0.fcstd
-side rod, rear part:
https://para.zonk.pl/Ol49forum/fcstd/05/P551-1-0.fcstd
- bushing, side rod, second and fourth axle:
https://para.zonk.pl/Ol49forum/fcstd/05/P555-1-0.fcstd
- radius rod:
https://para.zonk.pl/Ol49forum/fcstd/05/P574-1-0.fcstd
- lifting link:
https://para.zonk.pl/Ol49forum/fcstd/05/P576-1-0.fcstd
and assembly view:
- main rod:
- radius rod:
- lifting link:
and assembly view:
